Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
4.X call handler dial out through pstn
Looking to have the one caller input key from a call handler on one unity server, call out through the pstn to another remote unity server. (call handler /caller input says press 1 for toronto, 2 for chicago), etc. Is there a way to do this?
1 REPLY
Re: 4.X call handler dial out through pstn
I would have option one caller input go to attempt transfer to a NEW call handler that transfers to toronto. Just verify that your transfer rules in unity allow the outbound PSTN numbers. When you put your transfer in the new call handler just verify you have your access code included. example: 91555xxxxxxx
Hope this helps!
108
