Bronze
4507R LLQ????
We have just install 10MB layer 3 circuit between two 4507R at two different building.
There is no priority commnad under policy-map...
My question is that,
1. Can I upgrade to different verison of image at 4506R to fix the problem??
2. If not.. coz i look up the command for 4507R, there is no priority command.. so what do I do?? Is there another way to do LLQ at 4507R?
3. Move 10MB to router??
Ken
1 REPLY
Bronze
Re: 4507R LLQ????
Switches are slightly different. You need to check out http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a008073141d.html and look at how tx-queue 3 is used. Voice traffic should be placed there to insure that you're forwarding it via the strict priority queue. You'll assign your bandwidth in the priority queue under the tx-queue configuration like you used to do priority on your routers.
-- -Mark Turpin
108
