Community Member
486 Busy Here
So yesterday I had a fully functioning Cisco CME with a Callcentric SIP trunk, and today incoming calls are failing with a "486 busy here" message.  I can make outgoing calls with no problem.  Nothing has changed in the config since it was working.
Here is debug ccsip messages:
*Dec 28 19:33:47.663: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17772882353@24.39.49.190:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-7b2878d04ec1f664c1468281f717aca8
f: "Cell Phone   ME" <sip:12072277649@66.193.176.35>;tag=3597248031-456692
t: <sip:12072267262@ss.callcentric.com>
i: 6891983-3597248031-456662@msw1.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <sip:9b841dc194acd0ab62234389275bc2da@204.11.192.159:5080;transport=udp>
Supported: timer
c: application/sdp
l: 364
v=0
o=NexTone-MSW 15835 13386 IN IP4 204.11.192.159
s=sip call
c=IN IP4 204.11.192.159
t=0 0
m=audio 59388 RTP/AVP 0 18 96 101
a=maxptime:30
a=sendrecv
a=fmtp:101 0-15
a=rtpmap:101 telephone-event/8000
a=fmtp:96 mode=30
a=rtpmap:96 iLBC/8000
a=fmtp:18 annexb=no
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=silenceSupp:off - - - -
a=setup:actpass
*Dec 28 19:33:47.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Se
GMIT-VOICEROUTnt:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-7b2878d04ec1f664c1468281f717aca8
From: "Cell Phone   ME" <sip:12072277649@66.193.176.35>;tag=3597248031-456692
To: <sip:12072267262@ss.callcentric.com>
Date: Sat, 28 Dec 2013 19:33:47 GMT
Call-ID: 6891983-3597248031-456662@msw1.telengy.net
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 486 Busy here
To: <sip:12072267262@ss.callcentric.com>;tag=280830-25F5
CSeq: 1 INVITE
Reason: Q.850;cause=17
Content-Length: 0
*Dec 28 19:33:47.751: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17772882353@24.39.49.190:5060 SIP/2.0
t: <sip:12072267262@ss.callcentric.com>;tag=280830-25F5
CSeq: 1 ACK
Max-Forwards: 10
l: 0
ER01#
GMIT-VOICEROUTER01#
*Dec 28 19:33:53.003: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:12072267262@alpha15.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-6dcd081ae68ebfe2658fc27a157e44d0
CSeq: 1 ACK
Max-Forwards: 8
l: 0
1 ACCEPTED SOLUTION
Re: 486 Busy Here
Hi Eric
Can you try this for me and send a debug ccisip messages?
num-exp 17772882353 7011
see if you can dial 17772882353 from outside
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Community Member
486 Busy Here
Anyone?
486 Busy Here
is this happening for a particular phone or all phones?
could you please collect below debugs?
debug ephone detail
debug voip ccapi inout
debug ccsip message
//Suresh Please rate all the useful posts.
486 Busy Here
Hi Eric.
Checking your config on your previous thread, can you please change ephone-dn 82 to dual-line?
Carlo
Community Member
486 Busy Here
Carlo,
Yes I just did that for 81 and 82, then I had to re-setup the button on my test phone. Same result though.  Will post debugs below.
Community Member
486 Busy Here
Here are the debugs from an inbound call that fails with "party unavailable" recording:
debug ephone detail
This may severely impact system performance. Continue? [confirm]d
GMIT-VOICEROUTER01#ebug voip ccapi inout
% Invalid input detected at '^' marker.
GMIT-VOICEROUTER01#debug     debug voip ccapi inout
voip ccapi inout debugging is on
GMIT-VOICEROUTER01#debug ccsip message
SIP Call messages tracing is enabled
GMIT-VOICEROUTER01#
*Dec 30 16:52:50.816: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-78ba91246ea68b8e61d707aa505fa828
f: "Cell Phone   ME" <12072277649>;tag=3597411176-875822
t: <>12072267262@ss.callcentric.com>
i: 272535-3597411176-875786@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <0D036C82174EFA50E6B6A77EA97BBD5D>
Supported: timer
c: application/sdp
l: 364
v=0
o=NexTone-MSW 26817 24764 IN IP4 204.11.192.160
s=sip call
c=IN IP4 204.11.192.160
t=0 0
m=audio 61240 RTP/AVP 0 18 96 101
a=maxptime:30
a=sendrecv
a=fmtp:101 0-15
a=fmtp:96 mode=30
a=fmtp:18 annexb=no
a=setup:actpass
*Dec 30 16:52:50.824: //6766/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
GMIT-VOICEROUTCall Entry Is Not Found
*Dec 30 16:52:50.824: //-1/A7330314814B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=12072277649
   ----- ccCallInfo IE subfields -----
   cisco-ani=12072277649
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=17772882353
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Dec 30 16:52:50.824: //-1/A7330314814B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x494F8810, Call Info(
   Calling Number=12072277649,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=17772882353(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=700, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6766
*Dec 30 16:52:50.828: //-1/A7330314814B/CCAPI/ccCheckClipClir:
   In: Calling Number=12072277649(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=12072277649(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Dec 30 16:52:50.828: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 30 16:52:50.828: :cc_get_feature_vsa malloc success
*Dec 30 16:52:50.828:  cc_get_feature_vsa count is 1
*Dec 30 16:52:50.828: :FEATURE_VSA attributes are: feature_name:0,feature_time:1289480888,feature_id:57
*Dec 30 16:52:50.828: //6766/A7330314814B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=12072277649(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=17772882353(TON=Unknown, NPI=Unknown))
*Dec 30 16:52:50.832: //6766/A7330314814B/CCAPI/cc_process_call_setup_ind:
   Event=0x4A2CDF80
*Dec 30 16:52:50.832: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 17772882353
*Dec 30 16:52:50.836: //6766/A7330314814B/CCAPI/ccCallSetContext:
   Context=0x47DD3408
*Dec 30 16:52:50.836: //6766/A7330314814B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 6766 with tag 700 to app "_ManagedAppProcess_Default"
*Dec 30 16:52:50.840: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-78ba91246ea68b8e61d707aa505fa828
From: "Cell Phone   ME" <12072277649>;tag=3597411176-875822
To: <>12072267262@ss.callcentric.com>
Date: Mon, 30 Dec 2013 16:52:50 GMT
Call-ID: 272535-3597411176-875786@msw2.telengy.net
CSeq: 1 INVITE
Content-Length: 0
*Dec 30 16:52:50.840: //6766/A7330314814B/CCAPI/ccCallProceeding:
*Dec 30 16:52:50.844: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Dec 30 16:52:50.844: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Dec 30 16:52:50.844: : updating existing feature vsa
*Dec 30 16:52:50.844:  feature call basic
*Dec 30 16:52:50.844: //6766/A7330314814B/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
*Dec 30 16:52:50.848: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <>12072267262@ss.callcentric.com>;tag=990BDC8-214E
CSeq: 1 INVITE
Content-Length: 0
*Dec 30 16:52:50.904: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
t: <>12072267262@ss.callcentric.com>;tag=990BDC8-214E
CSeq: 1 ACK
Max-Forwards: 10
l: 0
*Dec 30 16:52:50.904: //6766/A7330314814B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x494F8810, Tag=0x0, Call Id=6766,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Dec 30 16:52:50.904: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 30 16:52:50.908: :cc_free_feature_vsa freeing 4CDBEAB0
*Dec 30 16:52:50.908: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 30 16:52:50.908:  vsacount in free is 0ER01#
GMIT-VOICEROUTER01#
*Dec 30 16:53:07.172: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-9ccc81ceef0a0001bb1ed78a4455f6bb
f: "Cell Phone   ME" <12072277649>;tag=3597411193-215572
i: 272663-3597411193-215528@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m:
Supported: timer
c: application/sdp
l: 364
v=0
s=sip call
t=0 0
m=audio 61256 RTP/AVP 0 18 96 101
a=maxptime:30
a=sendrecv
a=fmtp:101 0-15
a=fmtp:96 mode=30
a=fmtp:18 annexb=no
a=setup:actpass
*Dec 30 16:53:07.180: //6767/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*Dec 30 16:53:07.184: //-1/B0F35A4D8150/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=17772882353
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Dec 30 16:53:07.184: //-1/B0F35A4D8150/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6767
*Dec 30 16:53:07.184: //-1/B0F35A4D8150/CCAPI/ccCheckClipClir:
*Dec 30 16:53:07.184: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 30 16:53:07.184: :cc_get_feature_vsa malloc success
*Dec 30 16:53:07.188:  cc_get_feature_vsa count is 1
*Dec 30 16:53:07.188: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 30 16:53:07.188: :FEATURE_VSA attributes are: feature_name:0,feature_time:1289480888,feature_id:58
*Dec 30 16:53:07.188: //6767/B0F35A4D8150/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Dec 30 16:53:07.188: //6767/B0F35A4D8150/CCAPI/cc_process_call_setup_ind:
   Event=0x4A2CDF80
*Dec 30 16:53:07.188: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Dec 30 16:53:07.188: //6767/B0F35A4D8150/CCAPI/ccCallSetContext:
   Context=0x47DD5A18
*Dec 30 16:53:07.192: //6767/B0F35A4D8150/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 6767 with tag 700 to app "_ManagedAppProcess_Default"
*Dec 30 16:53:07.192: //6767/B0F35A4D8150/CCAPI/ccCallProceeding:
*Dec 30 16:53:07.196: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Dec 30 16:53:07.196: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Dec 30 16:53:07.196: : updating existing feature vsa
*Dec 30 16:53:07.196:  feature call basic
*Dec 30 16:53:07.196: //6767/B0F35A4D8150/CCAPI/ccCallDisconnect:
*Dec 30 16:53:07.200: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-9ccc81ceef0a0001bb1ed78a4455f6bb
From: "Cell Phone   ME" <12072277649>;tag=3597411193-215572
Date: Mon, 30 Dec 2013 16:53:07 GMT
Call-ID: 272663-3597411193-215528@msw2.telengy.net
CSeq: 1 INVITE
Content-Length: 0
Sent:
To: <>12072267262@ss.callcentric.com>;tag=990FDA8-DF8
CSeq: 1 INVITE
Content-Length: 0
*Dec 30 16:53:07.260: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
t: <>12072267262@ss.callcentric.com>;tag=990FDA8-DF8
CSeq: 1 ACK
Max-Forwards: 10
l: 0
*Dec 30 16:53:07.260: //6767/B0F35A4D8150/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x494F8810, Tag=0x0, Call Id=6767,
*Dec 30 16:53:07.264: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 30 16:53:07.264: :cc_free_feature_vsa freeing 4CDBEAB0
*Dec 30 16:53:07.264:  vsacount in free is 0
*Dec 30 16:53:08.372: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:12072267262@alpha5.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-c1461a555741ac74cd4bd429f69f3c0f
CSeq: 1 ACK
Max-Forwards: 8
l: 0
ER01#
GMIT-VOICEROUTER01#no debug all
All possible debugging has been turned off
GMIT-VOICEROUTER01#
Community Member
486 Busy Here
Anyone?
Re: 486 Busy Here
Hi Eric
Please let me know
Carlo
Community Member
486 Busy Here
Carlo,
Thank you for your help.  Callcentric has a 1777xxxxxxx number setup as my master phone number, and a local number as a DID.  I had DN's setup for both, but only had buttons setup on the phone for the DID.  When I added the master phone number to a phone, the line now rings!
Re: 486 Busy Here
Hi Eric.
Glad to know that now all is working.
Happy New Year!!!
Carlo
2718
