4FXS-DID configuration problem using BRI to receive/send calls from/to PSTN
Hi to all.
Follow is the partial configuration of my CME.
It has a 4FXS card to use analog phones and faxes, and 4 ISDN Basic Rate interfaces.
On each port of the 4FXS DID card happens the following:
If I enable direct-inward-dial
    I can receive calls from PSTN.
     Off hooking the analog phone I cannot hear any free line tone. I cannot make any call from that phone.
If I disable direct-inward-dial
    I cannot receive directly calls form PSTN.
          Callers on PSTN after typing my number, they hear a free tone. Then just typing the extension desired the phone ring.
     Off hooking the analog phone I hear a free line tone. I can make normal calls to everyone.
I have half the configuration working.
Where am I wrong?
I really appreciate your help.
Thanks to all.
Giorgio.
CME#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CME uptime is 2 days, 15 hours, 49 minutes
System restarted at 18:54:45 CDT Fri Aug 2 2013
System image file is "flash:/c2800nm-ipvoicek9-mz.124-24.T3.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FTX1120A08L
2 FastEthernet interfaces
16 terminal lines
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
1948656K bytes of USB Flash usbflash0 (Read/Write)
497448K bytes of ATA CompactFlash (Read/Write)
CME#sh telephony-service
CONFIG (Version=7.1)
Version 7.1
Cisco Unified Communications Manager Express
isdn switch-type basic-net3
voice translation-rule 1
rule 1 /^2929091\(..\)/ /\1/
rule 2 /^2929091\(.\)/ /\1/
rule 3 /^02929091\(..\)/ /\1/
rule 4 /^02929091\(.\)/ /\1/
voice translation-rule 2
rule 2 /\(.*\)/ /02929091\1/
voice translation-rule 10
rule 1 /\(^......$\)/ /0\1/ type national national plan isdn isdn
rule 8 /\(^......$\)/ /00\1/ type international international plan isdn isdn
voice translation-profile PSTN-IN
translate calling 10
translate called 1
voice translation-profile PSTN-OUT
translate calling 2
interface BRI0/0/0
description Isdn channels 1 & 2
no ip address
isdn timer T310 60000
isdn overlap-receiving T302 3000
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
interface BRI0/0/1
description Isdn channels 3 & 4
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI0/1/0
description Isdn channels 5 & 6
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI0/1/1
description not used
no ip address
shutdown
isdn send-alerting
isdn static-tei 0
voice-port 0/0/0
translation-profile incoming PSTN-IN
translation-profile outgoing PSTN-OUT
compand-type a-law
description Connessione con CO Telecom channels 1 & 2
voice-port 0/0/1
compand-type a-law
description Connessione con CO Telecom channels 3 & 4
voice-port 0/1/0
compand-type a-law
description Connessione con CO Telecom channels 5 & 6
voice-port 0/1/1
description Disponibile
voice-port 0/2/0
input gain 14
connection plar 83
description Interphone 40
station-id name Citofono
station-id number 40
caller-id enable
voice-port 0/2/1
cptone IT
description Ced 35
station-id name CED
station-id number 35
caller-id enable
voice-port 0/2/2
cptone IT
description FAX_1 50
station-id name FAX_1
station-id number 50
caller-id enable
voice-port 0/2/3
cptone IT
description FAX_2 60
station-id number 60
caller-id enable
dial-peer voice 1001 pots
description **Sends call to PSTN line 1-2**
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0
dial-peer voice 2001 pots
description **Receives calls coming from PSTN line 1-2**
destination-pattern 2929091..
incoming called-number .T
direct-inward-dial
port 0/0/0
dial-peer voice 1003 pots
description **Sends call to PSTN line 3-4**
port 0/0/1
dial-peer voice 2003 pots
description **Receives calls coming from PSTN line 3-4**
direct-inward-dial
port 0/0/1
dial-peer voice 1005 pots
description **Sends call to PSTN line 5-6**
port 0/1/0
dial-peer voice 2005 pots
description **Receives calls coming from PSTN line 5-6**
direct-inward-dial
port 0/1/0
dial-peer voice 2035 pots
description **Receives calls coming from PSTN to Extension 35**
answer-address 35
destination-pattern 35$
incoming called-number 35
port 0/2/1
dial-peer voice 2040 pots
description **Receives calls coming from PSTN to Extension 40**
destination-pattern 40
incoming called-number 40
no digit-strip
direct-inward-dial
port 0/2/0
dial-peer voice 2050 pots
description **Receives calls coming from PSTN to Fax 50**
destination-pattern 50
incoming called-number 50
no digit-strip
direct-inward-dial
port 0/2/2
dial-peer voice 2060 pots
description **Receives calls coming from PSTN to Fax 60**
destination-pattern 60
incoming called-number 60
no digit-strip
direct-inward-dial
port 0/2/3
CME#
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Remove incoming called-number under dial-peer.
Also progress_ind and various other commands are not needed.
Thanks Paolo for your fast answer.
But please be more specific.
On which of the dial-peers should I remove the command "incoming called-number"? On FXS dial-peers? Right?
Giorgio.
Re: 4FXS-DID configuration problem using BRI to receive/send cal
On all of them. Then add a single DP with "incoming-called number ." and direct-inward-dial.
Hi Paolo.
Sorry for the delay. I was on holiday.
I would like to keep separate incoming calls from outgoing calls.
So I decided to keep two dial peers for every BRI interface.
I followed your suggestion on eliminate commands:
"incoming called-number" on FXSs,
various "progress_ind" on BRIs
Also I eliminated  "direct-inward-dial" on FXSs,
Today I reconfigured and right tested the dial peers as following:
!   Bri Interfaces
port 0/0/0
direct-inward-dial
port 0/0/0
port 0/0/1
direct-inward-dial
port 0/0/1
port 0/1/0
direct-inward-dial
port 0/1/0
!   FXS interfaces
no digit-strip
port 0/2/1
no digit-strip
port 0/2/0
no digit-strip
port 0/2/2
no digit-strip
port 0/2/3
Thanks a lot Paolo. :-)
Giorgio.
Thank you for the nice rating and good luck!
Hello,Pls I need help in
Pls I need help in configuring an analog phone connected to VWIC3-4FXS/DID to be able to make pstn calls. currently it is making local calls to IP phones but when PSTN no is dialled, it responds with a fast busy tone. it's unclear why it does this. Appreciate your help.
Hi Emanuel.As my last
Hi Emanuel.
As on my last displayed config, I did configurations for dial peers attached to BRI lines and the four analog faxes.
Pay attention on how you compose the number on analog phone to get POTS. In my case I should manually prepend 0. Any other number will fall on locally configured number or on a busy tone.
If this does not help you enough, please open a new thread and attach your configuration. We will be very glad to help you.
Giorgio.
Hi Giorgio,Thanks for your
Hi Giorgio,
Thanks for your response. I already have my outgoing & incoming dial peers and relevant voice translations configured and currently all IP phones registered on the UC520's CME are working perfectly. They make and receive PSTN calls smoothly with DID through an E1 line.
I was only meant to setup the 4 FXS/DID ports to provide the same functionality for Analog phones. The phones can make on-net calls back and forth with IP Phones, they also receive incoming PSTN calls. However PSTN nos dialed from the Analog phones match the right outgoing dial-peer (seen from debug voice ccapi inout) but then returns a fast busy tone without the call going through.
I have checked everything and can't seem to find the problem, please help! Below is my partial config.
voice-port 0/0/0
station-id number 1234
caller-id enable
dial-peer voice 1234 pots
destination-pattern 1234
port 0/0/0
426
