4th FXO Line Not Working-Gives Half Rings
I am facing problem with 4 FXO lines configured on 2811 voice gateway with MGCP/CUCM7. Three lines are working perfectly on voice port 0,1 and 2, but when i connect 4th line on voice port 3 and calls from outside to inside then it gives half ring on the IP Phones instead of giving full ring. When i pick up the phone there is no response. Similarly i can't dialout using the same FXO port. I had connected other three working analog lines on this port and they work perfectly, which means the 4th port is fine. I had even used fifth analog number to ensure there is nothing wrong with the line, but the problem is not resolved. Please check the router configuration below and let me know what could be the possible issue?
Voice_Lab_Router#sh run
Building configuration...
Current configuration : 5507 bytes
version 12.4
hostname Voice_Lab_Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
logging buffered 51200 warnings
enable password cisco
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-2671316638
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2671316638
revocation-check none
rsakeypair TP-self-signed-2671316638
username admin password 0 cisco
archive
log config
  hidekeys
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 192.168.80.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.80.200
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0
timing hookflash-out 50
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.80.10
ccm-manager config
mgcp
mgcp call-agent 192.168.80.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
Thanks and Best Regards
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 4th FXO Line Not Working-Gives Half Rings
Nothing appears to be wrong.
You could try H.323 instead of MGCP as it's much more stable.
Likely it's gettin a power denial.
take "debug vpm signal" with "term mon". Do not enable any other debug, do not use attachaments.
You should also configure cptone according to your country.
Thanks for your prompt reply. I had already tried cptone but it's not working.
I forgot to mention that these lines were working on Nortel BCM first and now i am shifting to CUCM7.
Do what is indicated above, not just cptone.
The debug output is as follows:
Voice_Lab_Router#debug vpm signal
Voice Port Module signaling debugging is enabled
Voice_Lab_Router#
*Mar 14 21:44:13.016: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 14 21:44:13.016: htsp_timer - 125 msec
*Mar 14 21:44:13.144: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 14 21:44:13.144: htsp_timer - 10000 msec
*Mar 14 21:44:13.556: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 14 21:44:13.556: fxols_ringing_not
*Mar 14 21:44:13.556: htsp_timer_stop
*Mar 14 21:44:13.556: htsp_timer_stop3 htsp_setup_ind
*Mar 14 21:44:13.556: [0/0/3] get_local_station_id calling num= calling name= calling time=03/14 21:44  orig called=
*Mar 14 21:44:13.564: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 14 21:44:13.564: fxols_wait_setup_ack:
*Mar 14 21:44:13.564: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 14 21:44:13.564: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
*Mar 14 21:44:13.564: htsp_timer_stop
*Mar 14 21:44:13.572: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:13.572: htsp_call_bridged invoked
*Mar 14 21:44:13.576: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:13.816: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 14 21:44:13.816: htsp_timer2 - 350 msec
*Mar 14 21:44:14.168: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 14 21:44:14.168: htsp_timer_stop
*Mar 14 21:44:14.168: htsp_timer_stop2
*Mar 14 21:44:14.168: htsp_timer_stop3
*Mar 14 21:44:14.176: htsp_timer_stop3
*Mar 14 21:44:14.196: htsp_process_event: [0/0/3, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 14 21:44:14.196: htsp_timer_stop
*Mar 14 21:44:14.196: htsp_timer_stop2
*Mar 14 21:44:14.196: htsp_timer_stop3
*Mar 14 21:44:14.196: [0/0/3] set signal state = 0x4 timestamp = 0
*Mar 14 21:44:14.196: htsp_timer - 2000 msec
*Mar 14 21:44:15.576: htsp_process_event: [0/0/3, FXOLS_GUARD_OUT, E_DSP_SIG_0000]fxols_guard_out_ringing
*Mar 14 21:44:15.576: htsp_timer_stop fxols_onhook_ringing
*Mar 14 21:44:15.576: htsp_timer - 125 msec
*Mar 14 21:44:15.704: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 14 21:44:15.704: htsp_timer - 10000 msec
*Mar 14 21:44:16.076: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 14 21:44:16.076: fxols_ringing_not
*Mar 14 21:44:16.076: htsp_timer_stop
*Mar 14 21:44:16.076: htsp_timer_stop3 htsp_setup_ind
*Mar 14 21:44:16.076: [0/0/3] get_local_station_id calling num= calling name= calling time=03/14 21:44  orig called=
*Mar 14 21:44:16.084: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 14 21:44:16.084: fxols_wait_setup_ack:
*Mar 14 21:44:16.084: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 14 21:44:16.088: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
*Mar 14 21:44:16.088: htsp_timer_stop
*Mar 14 21:44:16.092: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:16.096: htsp_call_bridged invoked
*Mar 14 21:44:16.100: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:16.340: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 14 21:44:16.340: htsp_timer2 - 350 msec
*Mar 14 21:44:16.692: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 14 21:44:16.692: htsp_timer_stop
*Mar 14 21:44:16.692: htsp_timer_stop2
*Mar 14 21:44:16.692: htsp_timer_stop3
*Mar 14 21:44:16.700: htsp_timer_stop3
*Mar 14 21:44:16.716: htsp_process_event: [0/0/3, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 14 21:44:16.716: htsp_timer_stop
*Mar 14 21:44:16.716: htsp_timer_stop2
*Mar 14 21:44:16.716: htsp_timer_stop3
*Mar 14 21:44:16.716: [0/0/3] set signal state = 0x4 timestamp = 0
*Mar 14 21:44:16.716: htsp_timer - 2000 msec
*Mar 14 21:44:18.716: htsp_process_event: [0/0/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Mar 14 21:44:18.716: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Mar 14 21:44:20.264: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 14 21:44:20.264: htsp_timer - 125 msec
*Mar 14 21:44:20.392: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 14 21:44:20.392: htsp_timer - 10000 msec
*Mar 14 21:44:21.276: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 14 21:44:21.276: fxols_ringing_not
*Mar 14 21:44:21.276: htsp_timer_stop
*Mar 14 21:44:21.276: htsp_timer_stop3 htsp_setup_ind
*Mar 14 21:44:21.276: [0/0/3] get_local_station_id calling num= calling name= calling time=03/14 21:44  orig called=
*Mar 14 21:44:21.284: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 14 21:44:21.284: fxols_wait_setup_ack:
*Mar 14 21:44:21.284: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 14 21:44:21.284: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
*Mar 14 21:44:21.284: htsp_timer_stop
*Mar 14 21:44:21.292: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:21.292: htsp_call_bridged invoked
*Mar 14 21:44:21.296: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:21.536: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 14 21:44:21.540: htsp_timer2 - 350 msec
*Mar 14 21:44:21.892: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 14 21:44:21.892: htsp_timer_stop
*Mar 14 21:44:21.892: htsp_timer_stop2
*Mar 14 21:44:21.892: htsp_timer_stop3
*Mar 14 21:44:21.900: htsp_timer_stop3
*Mar 14 21:44:21.916: htsp_process_event: [0/0/3, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 14 21:44:21.916: htsp_timer_stop
*Mar 14 21:44:21.916: htsp_timer_stop2
*Mar 14 21:44:21.916: htsp_timer_stop3
*Mar 14 21:44:21.916: [0/0/3] set signal state = 0x4 timestamp = 0
*Mar 14 21:44:21.916: htsp_timer - 2000 msec
*Mar 14 21:44:23.916: htsp_process_event: [0/0/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Mar 14 21:44:23.916: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Mar 14 21:44:25.224: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 14 21:44:25.224: htsp_timer - 125 msec
*Mar 14 21:44:25.352: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 14 21:44:25.352: htsp_timer - 10000 msec
*Mar 14 21:44:26.236: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 14 21:44:26.240: fxols_ringing_not
*Mar 14 21:44:26.240: htsp_timer_stop
*Mar 14 21:44:26.240: htsp_timer_stop3 htsp_setup_ind
*Mar 14 21:44:26.240: [0/0/3] get_local_station_id calling num= calling name= calling time=03/14 21:44  orig called=
*Mar 14 21:44:26.244: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 14 21:44:26.248: fxols_wait_setup_ack:
*Mar 14 21:44:26.248: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 14 21:44:26.248: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
*Mar 14 21:44:26.248: htsp_timer_stop
*Mar 14 21:44:26.252: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:26.256: htsp_call_bridged invoked
*Mar 14 21:44:26.260: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
*Mar 14 21:44:26.500: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 14 21:44:26.500: htsp_timer2 - 350 msec
*Mar 14 21:44:26.852: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 14 21:44:26.852: htsp_timer_stop
*Mar 14 21:44:26.852: htsp_timer_stop2
*Mar 14 21:44:26.852: htsp_timer_stop3
*Mar 14 21:44:26.860: htsp_timer_stop3
*Mar 14 21:44:26.876: htsp_process_event: [0/0/3, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 14 21:44:26.876: htsp_timer_stop
*Mar 14 21:44:26.876: htsp_timer_stop2
*Mar 14 21:44:26.876: htsp_timer_stop3
*Mar 14 21:44:26.876: [0/0/3] set signal state = 0x4 timestamp = 0
I had changed to H.323 and still the same issue exists. First 3 lines are working and with 4th line it gives half ring
H.323 GW debug output is as follows:
*Mar 20 08:41:59.799: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 20 08:41:59.799: htsp_timer - 125 msec
*Mar 20 08:41:59.927: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 20 08:41:59.927: htsp_timer - 10000 msec
*Mar 20 08:41:59.927: htsp_timer3 - 5600 msec
*Mar 20 08:41:59.927: [0/0/3] htsp_start_caller_id_rx:BELLCORE
*Mar 20 08:41:59.927: [0/0/3] htsp_dsm_create_success  returns 1
*Mar 20 08:42:00.331: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 20 08:42:00.331: fxols_ringing_not
*Mar 20 08:42:00.331: htsp_timer_stop
*Mar 20 08:42:00.331: htsp_timer - 10000 msec
*Mar 20 08:42:01.519: [0/0/3] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
*Mar 20 08:42:01.523: htsp_process_event: [0/0/3, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
*Mar 20 08:42:01.523: htsp_timer_stop
*Mar 20 08:42:01.523: htsp_timer_stop3
*Mar 20 08:42:01.523: [0/0/3] htsp_stop_caller_id_rx. message length 23htsp_setup_ind
*Mar 20 08:42:01.523: [0/0/3] get_fxo_caller_id:Caller ID received. Message type=128 length=23 checksum=28
*Mar 20 08:42:01.523: [0/0/3] Caller ID String 80 14 01 08 30 33 32 30 31 31 34 30 02 08 36 37 30 37 37 36 33 32 28
*Mar 20 08:42:01.523: [0/0/3] get_fxo_caller_id calling num=67077632 calling name= calling time=03/20 11:40
*Mar 20 08:42:01.523: fxols_callerid_done: call being answered
*Mar 20 08:42:01.527: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 20 08:42:01.527: fxols_wait_setup_ack:
*Mar 20 08:42:01.527: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 20 08:42:01.531: [0/0/3] htsp_dsm_close_done
*Mar 20 08:42:01.539: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
*Mar 20 08:42:01.539: htsp_timer - 120000 msechtsp_alert_notify
*Mar 20 08:42:01.743: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
*Mar 20 08:42:01.779: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 20 08:42:01.779: htsp_timer2 - 350 msechtsp_call_service_msghtsp_call_service_msg not EFXS (2)
*Mar 20 08:42:02.131: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 20 08:42:02.131: htsp_timer_stop
*Mar 20 08:42:02.131: htsp_timer_stop2
*Mar 20 08:42:02.131: htsp_timer_stop3
*Mar 20 08:42:02.135: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 20 08:42:02.135: htsp_timer_stop
*Mar 20 08:42:02.135: htsp_timer_stop2
*Mar 20 08:42:02.135: htsp_timer_stop3
*Mar 20 08:42:02.135: [0/0/3] set signal state = 0x4 timestamp = 0
*Mar 20 08:42:02.135: htsp_timer - 2000 msec
*Mar 20 08:42:02.455: htsp_process_event: [0/0/3, FXOLS_GUARD_OUT, E_DSP_SIG_0000]fxols_guard_out_ringing
*Mar 20 08:42:02.455: htsp_timer_stop fxols_onhook_ringing
*Mar 20 08:42:02.455: htsp_timer - 125 msec
*Mar 20 08:42:02.583: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 20 08:42:02.583: htsp_timer - 10000 msec
*Mar 20 08:42:02.583: htsp_timer3 - 5600 msec
*Mar 20 08:42:02.583: [0/0/3] htsp_start_caller_id_rx:BELLCORE
*Mar 20 08:42:02.583: [0/0/3] htsp_dsm_create_success  returns 1
*Mar 20 08:42:02.891: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 20 08:42:02.891: fxols_ringing_not
*Mar 20 08:42:02.891: htsp_timer_stop
*Mar 20 08:42:02.895: htsp_timer - 10000 msec
*Mar 20 08:42:06.927: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0000]
*Mar 20 08:42:07.971: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 20 08:42:07.971: fxols_ringing_not
*Mar 20 08:42:07.971: htsp_timer_stop
*Mar 20 08:42:07.971: htsp_timer_stop3
*Mar 20 08:42:07.971: [0/0/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
*Mar 20 08:42:07.971: [0/0/3] get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
*Mar 20 08:42:07.971: [0/0/3] get_local_station_id calling num= calling name= calling time=03/20 08:42  orig called=
*Mar 20 08:42:07.979: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 20 08:42:07.979: fxols_wait_setup_ack:
*Mar 20 08:42:07.979: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 20 08:42:07.987: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
*Mar 20 08:42:07.987: htsp_timer - 120000 msec
*Mar 20 08:42:07.987: [0/0/3] htsp_dsm_close_donehtsp_alert_notify
*Mar 20 08:42:08.003: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alerthtsp_call_service_msghtsp_call_service_msg not EFXS (2)
*Mar 20 08:42:08.231: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 20 08:42:08.231: htsp_timer2 - 350 msec
*Mar 20 08:42:08.583: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 20 08:42:08.583: htsp_timer_stop
*Mar 20 08:42:08.583: htsp_timer_stop2
*Mar 20 08:42:08.583: htsp_timer_stop3
*Mar 20 08:42:08.587: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 20 08:42:08.587: htsp_timer_stop
*Mar 20 08:42:08.587: htsp_timer_stop2
*Mar 20 08:42:08.587: htsp_timer_stop3
*Mar 20 08:42:08.587: [0/0/3] set signal state = 0x4 timestamp = 0
*Mar 20 08:42:08.587: htsp_timer - 2000 msec
*Mar 20 08:42:10.587: htsp_process_event: [0/0/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Mar 20 08:42:10.587: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Mar 20 08:42:11.887: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 20 08:42:11.887: htsp_timer - 125 msec
*Mar 20 08:42:12.015: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 20 08:42:12.015: htsp_timer - 10000 msec
*Mar 20 08:42:12.015: htsp_timer3 - 5600 msec
*Mar 20 08:42:12.015: [0/0/3] htsp_start_caller_id_rx:BELLCORE
*Mar 20 08:42:12.015: [0/0/3] htsp_dsm_create_success  returns 1
*Mar 20 08:42:12.935: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 20 08:42:12.935: fxols_ringing_not
*Mar 20 08:42:12.935: htsp_timer_stop
*Mar 20 08:42:12.935: htsp_timer - 10000 msec
*Mar 20 08:42:16.811: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0000]
*Mar 20 08:42:17.615: htsp_process_event: [0/0/3, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
*Mar 20 08:42:17.615: htsp_timer_stop3
*Mar 20 08:42:18.015: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 20 08:42:18.015: fxols_ringing_not
*Mar 20 08:42:18.015: htsp_timer_stop
*Mar 20 08:42:18.015: htsp_timer_stop3
*Mar 20 08:42:18.015: [0/0/3] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
*Mar 20 08:42:18.015: [0/0/3] get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
*Mar 20 08:42:18.015: [0/0/3] get_local_station_id calling num= calling name= calling time=03/20 08:42  orig called=
*Mar 20 08:42:18.019: htsp_process_event: [0/0/3, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 20 08:42:18.023: fxols_wait_setup_ack:
*Mar 20 08:42:18.023: [0/0/3] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 20 08:42:18.027: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
*Mar 20 08:42:18.027: htsp_timer - 120000 msec
*Mar 20 08:42:18.031: [0/0/3] htsp_dsm_close_donehtsp_alert_notify
*Mar 20 08:42:18.047: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alerthtsp_call_service_msghtsp_call_service_msg not EFXS (2)
*Mar 20 08:42:18.275: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_DSP_SIG_1100]fxols_offhook_disc
*Mar 20 08:42:18.275: htsp_timer2 - 350 msec
*Mar 20 08:42:18.531: htsp_call_bridged invokedhtsp_call_service_msghtsp_call_service_msg not EFXS (2)
*Mar 20 08:42:18.539: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
*Mar 20 08:42:18.539: htsp_process_event: [0/0/3, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
*Mar 20 08:42:18.543: htsp_timer_stop
*Mar 20 08:42:18.627: htsp_process_event: [0/0/3, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
*Mar 20 08:42:18.627: htsp_timer_stop
*Mar 20 08:42:18.627: htsp_timer_stop2
*Mar 20 08:42:18.627: htsp_timer_stop3
*Mar 20 08:42:18.651: htsp_process_event: [0/0/3, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Mar 20 08:42:18.651: htsp_timer_stop
*Mar 20 08:42:18.651: htsp_timer_stop2
*Mar 20 08:42:18.651: htsp_timer_stop3
*Mar 20 08:42:18.651: [0/0/3] set signal state = 0x4 timestamp = 0
*Mar 20 08:42:18.651: htsp_timer - 2000 msec
*Mar 20 08:42:20.651: htsp_process_event: [0/0/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Mar 20 08:42:20.651: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
*Mar 20 08:42:21.931: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 20 08:42:21.931: htsp_timer - 125 msec
*Mar 20 08:42:22.059: htsp_process_event: [0/0/3, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 20 08:42:22.059: htsp_timer - 10000 msec
*Mar 20 08:42:22.059: htsp_timer3 - 5600 msec
*Mar 20 08:42:22.059: [0/0/3] htsp_start_caller_id_rx:BELLCORE
*Mar 20 08:42:22.059: [0/0/3] htsp_dsm_create_success  returns 1
*Mar 20 08:42:22.227: htsp_process_event: [0/0/3, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 20 08:42:22.227: fxols_ringing_not
*Mar 20 08:42:22.227: htsp_timer_stop
*Mar 20 08:42:22.227: htsp_timer - 10000 msec
842
