4th server to CM group
Don't have more than 3 server in my cluster but I wonder what happen when you try to add 4th server to CM group.
Any error message pop up?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 4th server to CM group
Hi Chris,
Very nice example of how to set up CCM Groups! +5 points my friend.
Cheers!
Rob
PS: Konrad, if you try to add a 4th CCM to a Group that already exists with 3 members, an error box will pop up preventing this action :)
Bronze
There should be no problems. Just add the server to the Pub as a node before you install and have the security password ready. Also confirm that your licensing on the pub allows for that additional node.
Please rate if this helped.
Edit: I didn't read the entire problem. You can only have 3 servers in a CM group. I thought you were asking in a cluster.
that is not correct:
A Cisco Unified Communications Manager Group specifies a prioritized list of up to three Cisco Unified Communications Managers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b02cmgrp.html
I'm not sure if you receive a pop-up or if simply the add arrow greys out, but for sure you cannot add a 4th member
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Silver
If you have more than 3 call processing servers you simply structure your groups to provide redundancy/load balances accordingly. I have one 10 node cluster with 8 call processing servers (8 is max) where I did 4 groups as following:
Group1:
Sub1, Sub2, Sub4
Group 2:
Sub3, Sub4, Sub2
Group3:
Sub5, Sub6, Sub8
Group4:
Sub7, Sub8, Sub6
This way you accomplish 1:1 redundancy where the even CMs are backups, and they are also secondary backups to other groups.
HTH,
Chris
Could you try to add 4th server to new Group5? I wonder what happen.
Thanks for nice redundancy example.
Not sure what you mean, I have 8 servers wich is the max distributed between 4 groups. You can create more groups if you want your deisgn to be different, but you can only have 3 CMs in a single group, CM will not let you add more.
HTH, Please rate all posts!
Chris
Hi Chris,
Cheers!
Rob
Thx Rob for information.
It will prevent it, it will not let you save and and give you the following error message:
" Update failed. A Cisco CallManager Group may not contain more than 3 Cisco CallManagers"
HTH,
Chris
712
