Community Member
5.X version of dblhelper
II was curious is there was a utility with the likeness of the dblhelper from version 4.x? I thought that was a quick and dirty way to see the health of your DB.
I know that version 5.X does not use SQL...If not, what is the best way to determine that synchronization is occurring without issue?
Thanks!
1 ACCEPTED SOLUTION
Re: 5.X version of dblhelper
the only way is to use the utils db_replication commands thru CLI, there is no more dblhelper on linux releases
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc
java
Green
We created CSCsi90821
Thanks for your input
145
