500 voice ports cisco unity connection HA
Hi all,
We are configuring a cisco unity connection Cluster with high availability and licenses for 500 voice ports.
The problem that we are facing is on the voice mail port wizard, i cannot add more than 250 ports.
I guess we have to create two new voice mail servers and add 250 ports to each one. Am i right?
what we have to do to integrate both voice mail server with the phone system on the unity connection side?
Any help is much appreciated
Kind regards
  • IP Telephony
Hall of Fame Super Silver
Correct, it is max 250 per each UCON server, so you need to build 2 groups.
To make it easier on yourself use SIP integration as there will be no need to build these on CUCM side. Only SIP trunk.
HTH,
Chris
VIP Super Bronze
+5 for Chris. Chris is spot on here..Its great when you do SIP integration. So I recommend that.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
For further reading:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg060.html#wp1052981
"A Connection cluster server pair supports up to 20,000 users. In this configuration, both servers can support up to 250 voice messaging ports each for a cumulative total of 500 voice messaging ports when both servers are active. If only one server is active, the port capacity is lowered to a maximum of 250 ports."
858
