5350 Sample Translation Rule
Hi all,
The carrier is sending us 3 digits which will start with a 7, I need to change this so the pattern reaching the PBX starts with a 1. I have been looking at the translation rules and am assuming that there is something extremely easy that I can do for this.
Max
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 5350 Sample Translation Rule
For the practical side:
dial-peer voice 10 pots
incoming called-number 7..
direct-inward-dial
translation-profile incoming 7to1
voice translation-profile 7to1
translate called 100
voice translation-rule 100
rule 1 /^7/ /1/
For the educational side of all that:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
good luck!
1 REPLY
direct-inward-dial
rule 1 /^7/ /1/
good luck!
138
