55 Incoming calls barred within Closed User Group (CUG) Problem
There is a mgcp gateway which use E1 pri to pstn network. CUCM version is 8.5. When call comes from pstn there is not any problem . But when ı try to terminate a call from ip phone to pstn network (via mgcp gateway) , ı have faced the the problem like below on real time monitoring tool,
is there anyone have faced same problem. Because we coudn't find any good  sollution about this problem.
router config:
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
Thanks.
Green
The first thing I notice is that you are trying to use QSIG-PRIM as
your ISDN switchtype
I dont think this is correct for the PSTN, usually you need to
use an NET type switch-type.
Like in the UK we need to use
PRIM -NET5
This needs to be set correctly both on the router IOS and
in CUCM gateway webpage.
Alex
Regards, Alex. Please rate useful posts.
Re: 55 Incoming calls barred within Closed User Group (CUG) Prob
I will change configuration as you said. but i think there is not any problem on isdn communication. because isdn status ok and call comes from pstn to ip phones( everything is ok).  When ip phone try to call to pstn side we faced the problem.
Thanks.
Green
After you have selected the correct ISDN switch-type for your country you
will need to confirm that you are sending the correct digits to the service provider.
A debug isdn q931
Will show what you are sending to line
Alex
2430
