6.1(2) to 7.1(3)B Upgrade
I am looking for clarification on upgrading from 6.1.2.1000-13 to 7.1(3)B.
I ordered the upgrade disks and have a disk to upgrade from 6.X to 7.1(3)B.
7.1(3)B release notes indicate that an upgrade is not possible from 6.1.2 but from 6.1.3 or higher.
I believe that I must upgrade to 7.1(2) as an interim step before upgrade to 7.1(3)B. Is this correct?
thanks
Ian.
Message was edited by: iwearing
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 6.1(2) to 7.1(3)B Upgrade
Hi Ian,
You really have two choices here
You can upgrade to a 6.1(3) version as a first step or 7.1(2) as
you correctly noted. Either way would be supported.
Cisco Unified Communications Manager Software Compatibility Matrix
Table 5 Supported Cisco Unified Communications Manager Upgrades for Release 7.1(x)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp108792
Tons of great info!
Take care,
Rob
Hi Ian,
Tons of great info!
Take care,
Rob
Rob,
Thanks for the clarification.
I have a set of 7.0(2a) disks which I can use as an interim step from 6.1(2) to 7.1(3b)
thanks
Ian.
237
