Community Member
6608-E1 CONFB with CUCM9.1
We are trying to use the old (which is gold) 6509 with WS-X6608-E1 blade for conference bridge with CUCM9.1. But it would never register with the callmanager. The configuration with the CatOS and on CUCM seems very simple and done as below:
On 6509 CatOS:
set port voice interface  6/1 dhcp enable vlan 150
On CUCM9.1:
Conference Bridge has been added as "Cisco Conference Bridge Hardware".
6509 Version:
Console> (enable) sh module
Mod Slot Ports Module-Type               Model               Sub Status
1   1    2     1000BaseX Supervisor      WS-X6K-SUP2-2GE     yes ok
15  1    1     Multilayer Switch Feature WS-F6K-MSFC2        no  ok
4   4    8     E1                        WS-X6608-E1         no  ok
6   6    8     E1                        WS-X6608-E1         no  ok
Mod MAC-Address(es)                        Hw     Fw         Sw
1   00-09-12-46-80-3a to 00-09-12-46-80-3b 4.3    7.1(1)     8.6(4)
15  00-06-52-67-79-c0 to 00-06-52-67-79-ff 2.5    12.1(11b)E 12.1(11b)E4
4   00-01-c9-d8-dd-1e to 00-01-c9-d8-dd-25 1.1    5.4(2)     8.6(4)
6   00-03-32-be-dd-2f to 00-03-32-be-dd-36 1.3    5.4(2)     8.6(4)
Following message keeps repeatedly appearing on the 6509 console for all the voice ports:
"2013 Sep 15 07:21:25 %SYS-4-MODHPRESET: Host process (860) 4/3 got reset asynchronously"
Any ideas?
Saif
Purple
Hi Saif,
Just a thought:
Can u check the MAC -address what u have configured in Cisco Call Manager undet conference bridge is  correct or not? You can run the command in 6509 chassis show port slot in which card is inserted.
regds,
aman
Community Member
Yes, MAC addresses have been thoroughly checked and verified.
Saif
Purple
Hi Saif,
I was just refering the DOC which points to MAC address issue.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a008045a3c0.shtml
Can u share the output of sh port and snapshot of what u have configured in call manager?
regds,
aman
Community Member
6509:
Port     DHCP    MAC-Address       IP-Address      Subnet-Mask
6/8     enable  00-03-32-be-3c-36 10.1.100.51     255.255.255.0
Callmanager snapshot attached.
Purple
Hi Saif,
After u added in Call manager, did u reset?
I am also not able to find what exactly is the issue since config seems to be OK.How many such modules do u have in 6509 chassis?
regds,
aman
Community Member
Running the tracy_start on one of the ports, gives following output. It seems that the CatOS is not able to parse the cnf.xml file and thats where its failing:
tracy_start 3 2
Console> (enable)
                         C i s c o   S  y s t e m s
                         CAT6K Digital Gateway (Lennon)
                         APP Version : D00404000032, DSP Version : D0054322, Built Apr 18 2008 15:08:16
                         Device Name : SDA0001C9D8BE1F
                         00:00:00.090 (XA) MAC Addr : 00-01-C9-D8-BE-1F
                         00:00:00.090 (NMP) Received message from XA Task
                         00:00:00.090 (NMP) Opening TCP Connection to IP 127.1.1.1 (0x7F010101)
                         00:00:00.090 (NMP) Sending Module Slot Info
                         00:00:00.190 (NMP) Received DIAGCMD
                         00:00:00.190 (NMP) Sending DIAGCMD TCP ACK
                         00:00:00.190 SPAN: Transmit clock slaved to span 1
                         00:00:00.190 SPAN: Transmit clock set to internal osc.
                         00:00:00.190 *** (FRMR) - Initializing E1 Framer ***
                         00:00:00.740 (DSP) Test Begin -> Mask<0xFFFFFFFF> Framer
                         00:00:01.220 (NMP) Show Port mNo:3, pNo:2
                         00:00:02.260 (NMP) Show Port mNo:3, pNo:2
                         00:00:03.290 (NMP) Show Port mNo:3, pNo:2
                         00:00:03.740 SPAN: Transmit clock slaved to span 1
                         00:00:03.740 SPAN: Transmit clock set to internal osc.
                         00:00:03.740 (DSP) Test Complete -> Results<0xFFFFFFFF/0xFFFFFFFF> tryCount<0>
                         00:00:03.740 (NMP) Received VLANCONFIG
                         00:00:04.320 (NMP) Show Port mNo:3, pNo:2
                         00:00:05.290 (CFG) Starting DHCP
                         00:00:05.290 (CFG) Booting DHCP for dynamic configuration.
                         00:00:05.510 (CFG) DHCP Request Sent, DHCPState = INIT_REBOOT
                         00:00:05.510 (CFG) DHCP  dtmf_on = 0, dtmf_off = 0
                         00:00:05.510 (CFG) DHCP Server ACK Processed, DHCPState = BOUND
                         00:00:05.510 (CFG) Requesting DNS Resolution of CiscoCM1
                         00:00:05.510 (CFG) DNS Unable to resolve TFTP Server Name CiscoCM1.
                         00:00:05.510 (CFG) TFTP Server IP Set by DHCP Option 150 = 10.1.150.101
                         00:00:05.510 (CFG) TFTP Server Backup IP Set by DHCP Option 150 = 10.1.150.102
                         00:00:05.510 (CFG) Requesting 0001C9D8BE1F.cnf.xml File From Primary TFTP Server after 20 sec
                         00:00:05.510 3 sec timer added
                         00:00:06.140 (NMP) Show Port mNo:3, pNo:2
                         00:00:07.170 (NMP) Show Port mNo:3, pNo:2
                         00:00:08.200 (NMP) Show Port mNo:3, pNo:2
                         00:00:08.510 TFTP_DHCP
                         00:00:08.510 (CFG) Handle Tftp Response for conf.xml.
                         00:00:08.510 (CFG) Try XMLDoParser, pBuffer[300000].
                        00:00:08.530 (CFG) Error [4] Parsing XML Configuration file.
                         00:00:08.530 (CFG) DHCPBlk<1A8> DeviceCfgBlk<800> gwConfig CONFIG_MAX<1658>
                         00:00:08.530 (CFG) Will use ROM config for missing XML config data.
                         00:00:08.530 (CFG) Parsing Error: Error Parsing XML File
                         00:00:08.530 (CFG) No ROM configuration available. Resetting in 15.
                         00:00:08.530 (DelBugTrap) Resetting in 15 second(s), Code<0x0806>
                         00:00:09.230 (NMP) Show Port mNo:3, pNo:2
                         00:00:10.270 (NMP) Show Port mNo:3, pNo:2
                         00:00:11.300 (NMP) Show Port mNo:3, pNo:2
                         00:00:12.340 (NMP) Show Port mNo:3, pNo:2
                         00:00:13.370 (NMP) Show Port mNo:3, pNo:2
                         00:00:14.400 (NMP) Show Port mNo:3, pNo:2
                         00:00:15.430 (NMP) Show Port mNo:3, pNo:2
                         00:00:16.460 (NMP) Show Port mNo:3, pNo:2
                         00:00:17.490 (NMP) Show Port mNo:3, pNo:2
                         00:00:18.520 (NMP) Show Port mNo:3, pNo:2
                         00:00:19.560 (NMP) Show Port mNo:3, pNo:2
                         00:00:20.590 (NMP) Show Port mNo:3, pNo:2
                         00:00:23.000 (XA) RESET Code<0x806>
I tried downloading the "0001C9D8BE1F.cnf.xml" file manually on the PC using the tftp client and the file looks absolutely good.
Saif
Purple
Hi Saif,
I won't be able to help on this issue.
If someone can help,please ..
regds,
aman
304
