Community Member
6921 Firmware upgrade problems
Hi All
Im running CUCM 7.1.3. Im In the process of upgrading the Firmware for my CP-6921 phone. Current firmware  SCCP69xx.8-5-4-0. After checking the upgrade notes the next firmware upgrade will be 9.0.(2). in order to upgrade the firmware cisco recommends install the 9.0.(2) QED file.
so i downloaded the file got a TFTP session going and then i received the following error message. Error Encounted: The selected file is not valid. MD5 HASH. I made sure the MD5 HASH matches.
Can anyone please advise on a solution to my problem. thanks in advance
2 ACCEPTED SOLUTIONS
It seems to be compatibility
It seems to be compatibility issue, as per below release note of this firmware "This version of firmware release 9.0(2) is compatible with Cisco Unified Communications Manager 8.0" it not showing that it is compatible with CUCM 7.1.3
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/6921_6941_6961/firmware/9_0_2/english/release/notes/6900_902.html
Suresh
Purple
Hi Suresh, I was just
Hi Suresh,
I was just checking cisco site where it says 9.0(2) is supported from CUCM 7.1(2) and above.
http://www.cisco.com/web/software/282074289/31576/cmterm-6921_6941_6961-sccp-9-0-2-0-readme.html
Before using the 9.0(2) firmware for Cisco Unified IP Phone models 6921, 6941 and 6961 with Cisco Unified CallManager release 7.1.2 and higher, you must install the latest firmware on all Cisco Unified CallManagerservers in the cluster. To upgrade phones from a load with 8.5(x), you need to upgrade to unsigned 9.0(2). Please download unsigned 9.0(2) and refer to unsigned 9.0(2) readme for upgrade
regds,
aman
Suresh
Community Member
ok perfect that makes sense.
ok perfect that makes sense. Any idea how i go about upgrading with current call manager version?
Community Member
Thanks to everyone who
Thanks to everyone who replied in such a short time frame. Amazing help from you guys!!!
Purple
Hi Suresh,
regds,
aman
Another instance of
Another instance of documentation glitch here (+5) for Aman :) Regarding the cucm upgrade, it will be a normal single step upgrade where you download the upgrade file for 7.1.5 from cisco.com and upload it on the Publisher followed by the subscribers. Then do a switch version on the Publisher followed by the subscribers. If your MCS server supports cucm version 7.1.5 then this upgrade comes at no extra cost. You should check for compatibility with other installed applications like UCCX and Unity Connection.
Manish
Nice catch by Suresh here, i
Nice catch by Suresh here, i would like to add that you can upgrade to cucm version 7.1.5, it will allow you to upgrade the phone firmware of 69XX phones to 9-3-3-2 with the latest device pack.
http://www.cisco.com/web/software/282074299/102827/cmterm-devicepack-7_1_5_36121-2_Readme.pdf
Manish
243
