Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
6921 Ip Phone EM button missing
I have an Ip telephony set up with CME 9.1.
I have enabled the EM on that and its working fine with 7945 and CIPC.
The issues is that the EM button is missing in 6921 button.The active load in 6921 is SCCP 9.3.1.3.
Please help to guide to resolve this issue.
Nithin Louis.
Green
Nithin,
Have you tried pessing the application key (looks like star just to top right of handset) you should see services and be able to select Ext Mob.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Re: 6921 Ip Phone EM button missing
Hi Alex,
Thanks for your mail.
Yes i tried that also .I presed the application keys I found the options like 1)call history(2)Preference.(3)Phone information (4)Admin settings.....but EM option is missing.
I google it for this issue and found that need to degrade the Firmawre.Please refer the below url for that.
https://supportforums.cisco.com/thread/2214101
But my IP telephony setup is in CME.
.I tried that also but I cannot degarde that.
I am getting the following error..
I download the cmterm-69xx-sccp.9-2-2-6.zip file from cisco.
upload the FM in the flash. using tftp. and gave the commands,
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.0-0-0-11.zz.sgn
tftp-server flash:SCCP69xx.9-2-2-6.loads
tftp-server flashSCCP69xx.9-2-2-6.zz.sgn
BDO_OMAN(config)#telephony-service
BDO_OMAN(config-telephony)#cnf-file location flash:
BDO_OMAN(config-telephony)#load 6921 SCCP69xx.9-2-2-6.loads
LOAD COMMAND MESSAGE: File flash:/BOOT69xx.0-0-0-14.zz not found
LOAD COMMAND MESSAGE: File flash:/DSP69xx.0-0-0-11.zz not found
LOAD COMMAND MESSAGE: File flash:/SCCP69xx.9-2-2-6.zz not found
LOAD COMMAND MESSAGE: File flash:/BOOT69xx.0-0-0-14.zz not foundLOAD COMMAND ERROR: File:flash:/BOOT69xx.0-0-0-14.zz HTTP binding creation failed, create tftp bindings manually
LOAD COMMAND MESSAGE: File flash:/DSP69xx.0-0-0-11.zz not foundLOAD COMMAND ERROR: File:flash:/DSP69xx.0-0-0-11.zz HTTP binding creation failed, create tftp bindings manually
LOAD COMMAND MESSAGE: File flash:/SCCP69xx.9-2-2-6.zz not foundLOAD COMMAND ERROR: File:flash:/SCCP69xx.9-2-2-6.zz HTTP binding creation failed, create tftp bindings manuallyUpdating CNF files
CNF files update complete for phonetype(6921).
Please refer the attached files for sh flash and sh telephony tftp-bindings.
Thanks & Regards
Nithin Louis.
Any update guys.....
Thanks & Regards
Nithin Louis
The issue is still not resolved.Guideance are welcome for resolving.
Thanks & Regards
Nithin Louis.
Green
Nithin,
Read this from the CME software compatability matrix
When configuring the load command:
In Cisco Unified CME 7.0(1) and later versions, use the complete filename including the file suffix when you configure the load command for phone firmware versions later than version 8-2-2 for all phone types except 69xx, 89xx, and 99xx phones
So you should NOT include the suffix in your load commands
telephony-service
401
