Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Bronze
6921 SURL Button issue
I can successfully use extension mobility on a 6921 handset and able to login and logout using the settings button.
If I bind a SURL to the second button and attempt to use EM from there I get a 207 Device Name Empty
I can replicate the configuration on a 7941 handset with the SURL button and it works well.
Re: 6921 SURL Button issue
I have the same issue.
Any solution for this anyone?
Super Bronze
What firmware are you running on the 7921?
There is a bug fixed in 1.0(2) (CSCsh35597) relating to this...
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/5_0_1/english/firmware/1_0_0/release/notes/rn7921_2_1030.pdf
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron,
Its a 6921 we are talking about not the 7921.
Super Bronze
Oops
Bronze
Yes this is a 6921 phone with fw 8.5.3.0 running on Communications Manager 7.1.3.10000-11
Thats fine Aaron...Thanks for posting anyways..
Heath, I am running the same firmware version with CUCM 7.1.3. I am gonna try upgrade to 9.0.2. If you have already tested with it let me know how it went!
Bronze
I have not upgraded FW as of yet.. Please let me know how you go.
I had the same problem with firmware 8.5.3.
Now i´m using version 9.0.2 and this problem were solved.
Bronze
Thats good news thanks.
I havea uploaded the firmware but when resetting the phones they don't actually take the upgrade. I have had an issue with the 7965s where I had to hold the # key at power up and press all the keys on the keypad to do a reset..
I don't want to do that on 1000 handsets.
May i know how u successfully configure 6921 with EM? cause i'm having trouble with this model to subscribe with services.
everytime i go into Services option, it prompt "Error! services unavailable". I've checked the URL for directory it look like this:
https://:8080/ccmcip/getservicesmenu.jsp
there's no problem for any other model deployed here such as 7911, 7940, 7960, 7961 & 7975.
Appreciate any kind of help. Thanks.
regards,
ss
1235
