6941/21 login softkey support
Hi, i'm running CCME 8.0 on a 2921 router; i can use the login softkey for call blocking override on cp-7962 but i can not use it on cp-6921/41. Does the the 6900 series support login softkey? if not,  may i use an ephone template. I'm using these firmware files:
SCCP69xx.8-5-3-0.loads
SCCP69xx.8-5-3-0.zz
BOOT69xx.0-0-0-14.zz
DSP69xx.0-0-0-3.zz
(Recommended on the compatibilty matrix0
Thanks.
1 REPLY
Re: 6941/21 login softkey support
I think problem was that phone comes with 9.0.2.0 firmware and i configured the tftp server to publish 8-5-3-0 firmware (i read in this forum that this downgrade can not be done), so the phone registers with an "other" phone type; i manually configured the phone type via CLI and now the login soft key is working fine.
212
