06-11-2014 06:23 AM - edited 03-16-2019 11:04 PM
We just upgraded the firmware in preparation for the 10.5 upgrade except 6941 all other phone models time shows correctly on the phone. Time displayed on 6941 is UTC/GMT time. If we downgrade the firmware back to the old one time shows up correct.
CUCM : 8.6.2
Firmware upgraded 9.4.1SR1
Old Firmware 9.2.2.6
Protocol used for the phone is SCCP
Thanks for your help.
06-11-2014 06:32 AM
Hi Balukr, I have seen this previously and resolved it by doing the following on the phone;
Settings > Admin Settings > Reset Settings > All
https://supportforums.cisco.com/discussion/12162681/daylight-saving-issues-uk-spring-2014
Richard
06-11-2014 06:35 AM
Thanks. I will try that and update here when I get to the site..
06-11-2014 11:14 AM
That's just necessary if you're having ITL issues which is causing the phone's config file to not be trusted. If you're having that issue, you should see things like "Trust List Update Failed" in the phone's status messages.
06-12-2014 01:54 AM
Hi Brian,
I had this issue for a client and this was the only work around i could find for it.
Richard
