6941 Phones and Call Back
Hi to all
we have 6941 phones and you already know that they have only one line.Call waiting is not supported by this series
So  we have creted another one virtual extension and when the first line is  busy then the second call going to the second extension
Everything is ok except call back
Lets say that the first extension has the number 800 and the second extension has the number 810
If  the number 800 is on the phone and the second call going to 810 then if  you set the  call back then it be assigned to 810 number.Is this  possible to be aasigned only to the 800 number , or when the call leave  from the 800 number and going to 810 then is not possible
Thank you
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Chrysostomos,
Sadly "Callback" is registered against the final number in this scenario which
would be 810 so it's really working as designed
But, as an FYI I thought you would like to know that the 6941 (6900 series)
does support "Multiple calls per Line" with CUCM 8.6 and Firmware 9.2.x
this info was nicely supplied by Gordon (GTC)
Check out Table 11;
Cisco Unified IP Phone Firmware 9.2(1) Features
The following table lists the new features and the Cisco Unified IP Phone families affected by the Cisco Unified IP Phone 9.2(1) firmware release. In some cases, features are only applicable to part of a phone family, and these restrictions are noted in the table. For more information about each feature and the phones that support the feature, see the sections that follow the table.
Table 11     Cisco Unified IP Phone Firmware 9.2(1) Features
Feature
Cisco Unified IP Phone 7900 Series Support
Cisco Unified IP Phone 6900 Series Support
Cisco Unified IP Phone 8961 and 9900 Series Support
Assisted Directed Call Park
Existing
New (SIP only, not all models)
Existing
Classic Ringtones
New (not all models)
Existing
CME Version Negotiation
New
Existing
EnergyWise
New (SCCP only)
New
New
Enhanced Call Forward Notification
New
Forced Authentication Code and Client Matter Code Support
Existing
Existing
New
HTTP Download
Existing
Missed Call Logs
Existing
Existing
Multiple Calls per Line Appearance
Existing
New
Existing
Next Generation Power over Ethernet
New
PLKs as Softkeys
New
SSH Access
New
New
New
Toast Timer
New
UCR 2008 Support
New (SCCP Only)
New (SCCP Only)
Widescreen Video Enhancements
New
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_6_1/delta/delta.html#wp2107810
Cheers!
Rob
Hi Chrysostomos,
Check out Table 11;
Feature
Existing
Existing
Classic Ringtones
Existing
New
Existing
EnergyWise
New (SCCP only)
New
New
New
Existing
Existing
New
HTTP Download
Existing
Missed Call Logs
Existing
Existing
Existing
New
Existing
New
PLKs as Softkeys
New
SSH Access
New
New
New
Toast Timer
New
UCR 2008 Support
New (SCCP Only)
New (SCCP Only)
New
Cheers!
Rob
Rob
You are like my hero
i knew that 6900 series didnt support multiple calls per line.Now with 8.6 it seems that is supported(new infos for me and really thank you for that....
Can i ask here the below or is better to open a new discussion
i HAVE a CUCM 8.5 cluster mode in a virtual Environment RUNNING ESXi 4.1..(UCS210)
I know that i have to follow the structure from the below link
  https://supportforums.cisco.com/docs/DOC-16898
BUT what happen with the ova file..i have to create a new virtual machine with the ova file for cucm 8.6?
what is the correct  Procedure for (cucm 8.6 upgrade) in a virtual Environment
If you can provide some links related to the correct Procedure in a virtual Environment it will be great
Many thanks
chrysostomos
Hi Chrysostomos,
You are always welcome my friend
We have not done that upgrade so probably a new thread is really your best bet
as there will be a number of "due diligence" type tasks to look after before upgrading.
Cheers!
Rob
489
