Community Member
6945 - Connecting Plantronics CS60 wireless headset
Newbie question so any assistance would be appreciated.
I am looking to find anyone who has successful connected a Plantronics CS60 wireless headset to a 6945 using an EHS cable.
From what I can see , this is not possible (the existing range of EHS cables are not compatible with 6945) and the only way do have this functionality is to use a lifter.
I know that some of these cables sometimes work on different phone models - It's just that they are not officially "Certified" so are not advertised as compliant.
Has anyone successfully tried this? Or am I wasting my time with this?
I have tried the APC- cable without any luck
Again thanks in advance for any assistance
Hall of Fame Super Red
Hi Stephen,
The release of firmware version 9.3.3 does add support for the EHS
function on 6945's;
Electronic Hookswitch
The Electronic Hookswitch feature enables users to remotely  control basic IP phone functionality from a wireless analog headset  connected to the phone auxiliary port. Basic IP phone functionality  includes off-hook/on-hook, ring indication, audio volume control, and  mute/unmute.
The administrator enables or disables the Electronic Hookswitch feature.
The user connects a base station to the auxiliary port. The base station communicates with the wireless headset.
The Electronic Hookswitch feature supports the following headsets:
  • Jabra
    • PRO9400 and GO6400 series and Straight cable (Jabra Link14201-22)
    • PRO920, GN9300 series and GN9120 the adapter cable Link 14201-16
This feature is supported on the following phones (SCCP and SIP):
  • Cisco Unified IP Phone 6945
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/6900_series/firmware/933/release_notes/P069_BK_R9A78776_00_rn-9_3_3-6900-series_chapter_00.html#IP95_TP_E7F8E2EE_00
But as you can see it is only Jabra Headsets that have been tested so far. If you are @
9.3.3 and can enable EHS, I might try the APC-41 or just be patient and I'm sure that
Plantronics will add support in the near future
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
Community Member
Thanks for the quick reply Rob -
Yes we are at 9.3.3 and No we couldnt get it to work wth the APC-41
Im just wondering because the CS60 has been around a while (and support for the 6945 is notably absent from the Plantronics line up) if they will actualy put out an EHS cable that supports it.
Its strange - It is supported on say the 9951 - and I cant imagine the EHS function is so very different between these models.
Might be worth me contacting Plantronics to see what they have to say -
Thanks again
Stephen
1088
