69xx Firmware issues
HI All,
Im building a new CUCM10.5 cluster. prior to migrating phones, ive been asked to bring the firmware on our current phones up to the same default firmware on the 10.5 CUCM
currently, my phones are on an old 8.0.3 system. the firware on these 6921/6941s is "SCCP69xx.9-0-3-0".
according to the doco, i should be able to do a direct upgrade to "SCCP69xx.9-4-1-3SR1 "
I have installed, the COP file, restarted the TFT service. i can download the required files from my tftp server using a tftp client.
i have set a phone-load manually on 2 tests phones.
my phones get the files, but dont seem to be able to register.
i recall seeing that you have to install some device packs in going to 9.3.3, but 9.4.1 has no device pack i can see.
Any thoughts?
1 ACCEPTED SOLUTION
I believe starting with 9.3,
I believe starting with 9.3, the 69XX series started doing security by default.  Because of this, the phones start asking for signed config files after the firmware upgrade.  You need to install the latest device pack on CUCM to support building the signed config files for this model phone.  You can install the device pack and then just change the device defaults to the newer firmware version you installed if the latest device pack includes an older firmware version.
If you installed the cop file
If you installed the cop file, and are able to download the files from the tftp server, the server side should be ok.
There is a different reason why the phones are unable to register. Have you tried taking packet captures? On the CUCM, in the device page, are you able to see the phone's IP address?
What about the SEPmac.cnf.xml file? Does it contain all the right details for the phone to register?
373
