7821 Cisco Phone with SRST Issue
Hello good day
dears please support me
i have 7821 ip phone and its SIP phone and its not working with SRST  in branch location . and as ber Cisco Compatibility Information can support from SRST v 8.6 and i'm already upgrade my routers IOS to 15.0 to support SRST 8.6 adn its not working . do you have any idea
 http://www.cisco.com/c/en/us/support/unified-communications/unified-survivable-remote-site-telephony/products-device-support-tables-list.html
Phone 7821
Routers 2801  IOS 15.1
             1861   IOS 15.1
               880   IOS 15.3
Thanks & Best Regards,
Hall of Fame Super Silver
Please post your SIP SRST
Please post your SIP SRST configuration so we can confirm proper config.
Chris
Hello, kindly find in the
kindly find in the below the router configuration
call-manager-fallback
 max-conferences 2 gain -6
 transfer-system full-consult
 ip source-address X.X.X.X port 2000
 max-ephones 5
 max-dn 10
 keepalive 40
Thank You :)
This SCCP SRST config, you
This SCCP SRST config, you need sip SRST for 78xx phones.
chris
dear Chris, could you please
dear Chris,
could you please help me for the SIP configuration please
many thanks
Here you go:voice register
Here you go:
voice register global
 system message SRST Active
 max-dn 200
 max-pool 10
voice register pool  1
 id network 10.x.x.0 mask 255.255.255.0
Chris
hello Chris thanks a lot for
hello Chris
thanks a lot for your kind support.
but sorry its not working :(
any extra idea .
thanks & Best Regards,
the below for your info
RTR#show voice register pool all
 Pool Tag 1
Config:
  Network address is 10.106.52.1, Mask is 255.255.255.0
  Proxy Ip address is 0.0.0.0
  DTMF Relay is disabled
  kpml signal is enabled
  Lpcor Type is none
  Reason for unregistered state:
         No registration request since last reboot/unregister
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
Statistics:
  Active registrations  : 0
  Total SIP phones registered: 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   :
    Last unregister request time :
    Register success time        :
    Unregister success time      :
Do you have SRST reference
Do you have SRST reference properly configured in CUCM and assigned to the phones'  device pool?
Dear Chris, yes SRST
Dear Chris,
yes SRST reference assigend to phone device pool as per attached pic.
Can you provide "debug ccsip
Can you provide "debug ccsip all" when the phones are suppose to register. Did you define proper subnets of the phones under the voice register pool?
Chris
Dear Chris, yes the subnet
Dear Chris,
yes the subnet under the voice register poll is correct.
and i'm enabled the Debug CCSIP all
INT-RDS-RTR#show debug
  Persistent variable debugging is currently All
CCSIP SPI: SIP Call Statistics tracing is enabled       (filter is OFF)
CCSIP SPI: SIP Call Message tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call State Machine tracing is enabled    (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled   (filter is OFF)
CCSIP SPI: SIP error debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP info debug tracing is enabled    (filter is OFF)
CCSIP SPI: SIP media debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP Call preauth tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call transport tracing is enabled        (filter is OFF)
CCSIP SPI: SIP DHCP tracing is enabled  (filter is OFF)
INT-RDS-RTR#
the below FYI
  Version 10.0
  Mode is srst
  Max-pool is 5
  Max-dn is 50
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  Forced Authorization Code Refer is enabled
  System message is SRST Active
  timeout interdigit 10
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
  MWI unsolicited notify is disabled
do you need show run for all voice configuration on the router ??
Thanks & Bet Regards,
There is nothing showing in
There is nothing showing in the debug implying the phones do not even attempt to register, yes please provide full config,
Chris
 Dear Chris kindly find the
Dear Chris
kindly find the attached full config for the router ز
Thank you for your interest to help me :]
Best Regards,
Try adding: Voice service
Try adding:
Voice service voip
 allow-connections sip to sip
 sip
   registrat server
In my case that was the
In my case that was the solution!!
Thanks!!
Dear Sir,
Dear Sir,
We have two Sites .example site A and Site B.call manager Bussiness Edition 6000 is placed in site-A and Site-B phones are registered on this BE 6000 through VPN.In Site-B there is a SRST Router  for  the redundancy
In site-B there is cisco 7975,7962 ,cp 6921 and cp7861 iphones
After finishing the configuration 7675 and 7962 is able to register on srst router after loss the connectivity of BE 6000.but  cp 6921 and cp7861 iphones are not registering on srst router.Please help me
Find the configuration  of SRST Router. Please let me know what are the changes i should make
Please Please help me
Building configuration...
Current configuration : 4445 bytes
! Last configuration change at 12:17:18 UTC Sat Apr 2 2016
version 15.4
hostname AUH_SRST
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
enable password admin
no aaa new-model
ip dhcp excluded-address 192.168.50.129
ip dhcp excluded-address 192.168.50.130
ip dhcp pool VOICE
import all
network 192.168.50.128 255.255.255.128
default-router 192.168.50.130
option 150 ip 10.10.3.251 10.10.3.250
lease 30
ip cef
no ipv6 cef
trunk group AUH_FXO
hunt-scheme round-robin
cts logging verbose
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice iec syslog
mode esrst
timeouts interdigit 3
system message ETA_FallBack
max-dn 20
max-pool 20
id network 192.168.50.128 mask 255.255.255.128
no digit collect kpml
dtmf-relay rtp-nte
codec g711ulaw
voice translation-rule 1
rule 1 /[0-9]+/ /9&/
rule 2 /971/ /900971&/
voice translation-profile FROM_ISP
translate calling 1
license udi pid CISCO2921/K9 sn FCZ193661MR
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description #MANAGEMENT#
encapsulation dot1Q 10
ip address 192.168.22.5 255.255.255.248
interface GigabitEthernet0/0.60
description #vOICE vLAN#
encapsulation dot1Q 60
ip address 192.168.50.130 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.130
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.129
control-plane
voice-port 0/0/0
trunk-group AUH_FXO
translation-profile incoming FROM_ISP
cptone AE
timeouts call-disconnect 5
timeouts wait-release 5
timing guard-out 1000
connection plar opx 5333
caller-id enable
voice-port 0/0/1
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/2
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/3
trunk-group AUH_FXO
cptone AE
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 1000 voip
destination-pattern 5333
session target ipv4:10.10.3.250
voice-class codec 1
dial-peer voice 1001 voip
destination-pattern 53..
voice-class codec 1
sip-ua
gatekeeper
shutdown
secondary-dialtone 9
max-conferences 8 gain -6
timeouts interdigit 5
ip source-address 192.168.50.130 port 2000
max-ephones 25
max-dn 50 dual-line
system message primary ETA_MELCO_LOCAL
system message secondary ETA_MELCO_LOCAL
transfer-pattern .T
keepalive 20
call-forward pattern .T
call-forward busy 5333
call-forward noan 5333 timeout 45
time-zone 35
date-format dd-mm-yy
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password admin
login
transport input telnet
scheduler allocate 20000 1000
end
AUH_SRST#
2859
