7821 IP Phone With SRST Problem
Dears Good day ,
kindly i have 7821 IP Phone and its working fine but SRST not working in another location or site and as ber Cisco Compatibility Information the SRST compatible with 7821 starting from SRST version 8.6 . and SRST 8.6 compatible with IOS 15.1 .
http://www.cisco.com/c/en/us/support/unified-communications/unified-survivable-remote-site-telephony/products-device-support-tables-list.html
and i'm already upgraded my routers to 15.1 but SRST not working . but before was working will with ATA & 69XX IP phones .
do you have any idea or any support :)
the below for your info..
Routers 2801 , 1861 . 880
IOS 15.1 , 15.1 , 15.3
CUCM 9.1.1.20000-5
Thanks & Best Regards,
Everyone's tags (1)
Hi there,Can you post your
Hi there,
Can you post your config?  Ensure you have the proper SIP SRST config on your gateways in addition to the standard SCCP SRST a config:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_call_handling.html#pgfId-1052492
Chris
HI Clileikis, kindly find in
HI Clileikis,
kindly find in the below the router configuration
call-manager-fallback
 max-conferences 2 gain -6
 transfer-system full-consult
 ip source-address X.X.X.X port 2000
 max-ephones 5
 max-dn 10
 keepalive 40
Thank You
VIP Purple
Hi, Did u enter the IP
Did u enter the IP address under SRST reference configuration in SIP network/IP address in CUCM even though it is not mandatory?
regds,
aman
Hi there,I'd suggest taking a
Hi there,
I'd suggest taking a look at my previous link and populating the voice register global commands.
Chris
686
