7821 SRST with CUCM 8.6 Yes or No?
Ok, trying to make the question simple for hopefully a simple answer…
We are looking at using the 7821 SIP phones as the current 6921 SCCP phones are now end of sale etc…
We have them working fine normally but unsure about SRST in branch locations vis MGCP
Question: Can we provide SRST support for the 7821 SIP phones via the following setup;
  • CUCM 8.6.2.23900-10
  • 2911 Router – IOS 151-4.M5
  • MGCP
There are conflicting documents and I cant get a definitive answer?
Any one running these?
1 ACCEPTED SOLUTION
Dear , Please check the below
Dear ,
Please check the below configuration i was have the same issue with 7821 and working fine now
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 sip
  registrar server expires max 600 min 60
voice register global
 system message SRST Active
 max-dn 50
 max-pool 19
voice register pool  1
 id network xx.xx.xx.xx mask xx.xx.xx.xx
 dtmf-relay rtp-nte cisco-rtp sip-notify
 codec g711ulaw
 no vad
sip-ua
 registrar ipv4:yy.yy.yy.yy expires 600
On UCM SRST reference configuration for gateway
SIP Network/IP Address : yy.yy.yy.yy
SIP Port :  5060
for xx.xx.xx.xx insert the network ID
for yy.yy.yy.yy insert Gateway IP
Best Regards,
Compatibility is herehttp:/
http://www.cisco.com/c/en/us/support/unified-communications/unified-survivable-remote-site-telephony/products-device-support-tables-list.html
java
if this helps, please rate
www.cisco.com/go/pdi
Well, see that is just the
Well, see that is just the issue....
when following  the link for 8.6, it shows support for 7821's and also the 8.6 Vs IOS it shows the below which is good;
15.1(4)M
8.6 - Recommended Version
8.6.0.0
Cisco Unified CME 8.6 Specifications
However when following the link to the right (Cisco Unified CME 8.6 Specifications), the is no listing for 78xx. Bit contradictory.
That is why I am asking if anyone has done before via the same combination.
Dear ,
voice service voip
 sip
 max-dn 50
 max-pool 19
 codec g711ulaw
 no vad
sip-ua
SIP Port :  5060
Best Regards,
621
