Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
7825-H3 RAID Configuration
I have two 7825-H3's out of the box that don't have RAID configured or anything. These will be part of a new 6.1 cluster that we will be upgrading from 4.2, so the 6.1 disks came separately.
Whenever I try to load from the disk I get the following
Disk size [149 GB] failed check [MIN needed 232 GB]
I even tried configuring the RAID array manually prior to bootup but I get the same exact error.
These are two 160GB drives.
Has anyone seen this one?
Thanks in advance
Green
Re: 7825-H3 RAID Configuration
Hey,
Did u get the server from us or from HP?
BAsed on your description looks like disk size is fine...
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd805e6fac.html
Are you using 6.1 disk?
Per the error looks like Media doesnt recognize this new valid server (h3)
What is the exact version are you installing 6.w(x)yyyy-z ??
Interesting tidbit of info if anyone ever encounters this. The server had extra RAM installed to put it up to 6GB instead of the normal 2.
Once I pulled the extra RAM out, it worked fine.
I guess the DVD has some RAM flag in it or something and maybe it thought it was a 7845, not sure of the cause, but I do know the fix.
Green
Thanks for the update
415
