7841 call waiting display
The user guide for the 7841 says the following about Call Waiting and multiple calls on the same line;
Respond to Call Waiting Notification
Perform one of the following actions to answer a waiting call:
Scroll to display the sessions if the call is on the same line but not visible.
However on a current rollout of some 7841s it's been observed that when a second call comes in on the primary line, after the call toast fades out there is no way to view the info about the waiting call.  Pressing the up/down navigation buttons has no effect.
Am I misinterpreting the instructions in the User Guide or is this phone not doing what it is supposed to?
Thanks.
Hi, Respond to call waiting
Respond to call waiting notification
This feature is applicable only if your phone supports multiple lines
and ip phone 7841 is mentioned in this doc
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7821_7841_7861/10_1/english/user_guide/PA2D_BK_UB7EF0F0_00_user-guide-7821-7841-7861/PA2D_BK_UB7EF0F0_00_user-guide-7821-7841-7861_chapter_010.html#PA2D_TK_R67378C8_00
Call waiting Notification lets users receive a second incoming call on the same line without disconnecting the first call. When the second call arrives, the user receives a brief call-waiting indicator tone, which is configured with the Ring Setting (Phone Active) in the Directory Number Configuration window.
Configure call waiting in the Directory Number Configuration window in Cisco Unified Communications Manager Administration by setting the busy trigger (greater than 2) and maximum number of calls.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_0_1/ccmsys/cucm-accm-701/a03dn.html#wp1098941
Aateek Singh
Network Engineer
Spooster IT Services
So are you saying I am right
So are you saying I am right or am I wrong?  Is the phone not doing what it is supposed to do?
When a second call comes in and after the toast fades out, should pressing the up/down navigation buttons display the info for the waiting call as the doc implies?
Hi, I would suggest you to
I would suggest you to first check the busy trigger value in CUCM because if the busy trigger value set is not greater that 2 then call waiting for phones will be configured with no display
please refer the the same Doc in previous reply.
Aateek singh
Network Engineer
So if busy trigger is set to
So if busy trigger is set to 2 (which is the default) you could be on an active call, a second call could come in and then once the call toast has faded out there's no way for the end user to retrieve the display of the waiting call?  Does that not seem a bit odd?
235
