7841 registration issue on CUCM Business Edition 9.x
Hi all,
even if 7841 Cisco Data S. says 7841 is compaltible for
8.6.2
9.1.2
10.x and later
seems this is not true .
Actually 7841 works only with 10.x
Anyone Knows more about or has a solution ?
Best regards
CARLO
VIP Gold
Hi Carlo,What is the actual
Hi Carlo,
What is the actual problem you are facing with these phones ?
By the way, if you are not seeing the device type (7841) while adding it to cucm, then plz install latest device pack in cucm.
Suresh
It seems that 7841 does not
It seems that 7841 does not have device pack for CUCM 9.X
There is for 9.1(x), if you
There is for 9.1(x), if you're running 9.0(x), you won't find one, and you need to upgrade to a compatible release.
Cisco Unified IP Phone Feature and Cisco Unified Communications Manager Device Pack Compatibility Matrix
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Gold
You can find the latest
You can find the latest device pack for 9.1.2 at below link.
http://software.cisco.com/download/release.html?mdfid=284510097&softwareid=282074299&release=9.1%281.21017%29&relind=AVAILABLE&rellifecycle=&reltype=all
Suresh
152
