04-01-2014 05:20 AM - edited 03-16-2019 10:19 PM
This is the description of the issue, which occurs occassionaly:
Cluster/phone info
Phone set up is as follows:
Additional info:
Initial conclusions:
If you have any thoughts, please share them - this is truly a mystery to me!
Thank you
Solved! Go to Solution.
04-01-2014 06:30 AM
Hi James, this is my take on it , though it is a very strange issue.
Based on you're initial conclusions.
1.In my opinion to get a call to move from active to on hold and then take a new call is not going to because by any layer2/3 network issue, so i would rule that one out.
2.There is no config i know that would create the issue you are having so again i would rule out a config error / difference.
3.Interesting one this , given that this only occurs at this site this would be the obvious conclusion however strange the issue.I have seen weird things in the past with new phones having sticky keys i.e getting stuck down.
4.Again this could be the obvious one , but again its a strange issue and would involve multiple key presses , so i doubt this one aswell.
To summarise i would go with the sticky keys option first , i.e maybe swop a few phones or at least ask the user to press all the buttons on the phone repeatedly to free them up.
04-01-2014 06:30 AM
04-12-2014 12:33 PM
I sent a request to the customer to replace the phone the same I day I posted the original thread. As of this update, that was 11 days ago. Customer did not replace phone and has not reported the issue again. I believe Markbatts was right; stuck buttons or similar physical phone issue.
