7902 feature buttons question
Use a bunch of Cisco 7902G IP phones in production.
These phones have 4 feature buttons:
1. Redial
2. Transfer
3. Conference
4. Messages
As far as I understand these buttons are fixed. But perhaps there is some possibility to change/disable them. For example we need to disable "Redial" function. Does anyone know is it possible or not?
Thanks in advance.
  • IP Telephony
1 ACCEPTED SOLUTION
1 and 2 cannot be
1 and 2 cannot be disabled
Well you cannot disable any of them actually, but since 3 and 4 depend on CUCM config, you can make it so that they don't work by adjusting the CUCM config.
java
if this helps, please rate
www.cisco.com/go/pdi
1 REPLY
1 and 2 cannot be
java
24
