09-17-2008 06:37 AM - edited 03-15-2019 01:20 PM
Call Manager 4.1(3)
Unity 4.2(1)
7905 Phone
We have one 7905 phone that has it's message waiting light on...but no voicemail is set up for this extension, so there's nothing in Unity, and no voice mail profile in Call Manager.
Resetting the phone doesn't turn it off.
What can be done to get the light to go off?
Solved! Go to Solution.
09-17-2008 06:48 AM
just dial the MWI DN number off
which u can find the number at :
From within CCMAdmin, select Feature>Voice Mail>Message Waiting
search for mwi off
when u dial it from any phon should switch off
and check if there is another subsecribure number on unity has configured to light that phone for extra check
good luck
if helpful Rate
09-17-2008 06:48 AM
search for mwi off
good luck
if helpful Rate
09-18-2008 07:59 AM
That worked, thank you so much.
Is there any way to do this remotely?
09-18-2008 08:04 AM
Ocassionally if you reset the phone from the GUI it will take care of the stuck MWI light.
Steve
