02-09-2007 09:13 AM - edited 03-14-2019 07:57 PM
hi friends, i have this problem, when 7906 goes in SRST(Call-manager-fallback) they are unable to register with Gateway 2811 with that ios version, when they are registered with CCM all goes right.What is the problem? someone can help me?
thanks a lot for all
02-09-2007 09:21 AM
Are both CM and SRST addressess appearing in the settings menu of 7906 ?
I would also upgrade anyway to 12.4(9 or 11)T to sort out any bug in older version.
At the same time check the load revision on the phones.
02-11-2007 11:50 PM
Yes, now I'll try with another ios. It can be a possible bug in older version. Thanks for all. I try.
