Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
7906 Softkeys
Is there any way to program a softkey for anything other then the options given? I am using one of these phones as a doorway phone and want one of the button as a speeddial that they push to ring the receptionist.
Hall of Fame Super Red
Re: 7906 Softkeys
Hi Jason,
Unfortunately you won't be able to use a Softkey for this function. Have you thought about just configuring the 7906 to Hotdial the receptionist when the handset goes Off-Hook?
Hotdial on IP Phones with CallManager Configuration Example
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Hope this helps!
Rob
Super Bronze
Re: 7906 Softkeys
Hi Jason
You currently can't configure 'custom' softkeys on any Cisco phones... you can add/remove the standard ones but can't add speed dials or service URl shortcuts as softkeys.
If PLAR as Rob suggested isn't any good you could use a multi-line-button phone (e.g. 7941) and use the second line as a speed dial.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
160
