7906G DOES'NT START
I have CCME 4.1 with 7906G Phones (over WAN)
7906G firmware is jar11sccp.8-0-2-25.sbn
After power loss 7906 does'nt start
saying;
"downloading term06.default"
I cannot access the telephone anymore.
1 REPLY
Re: 7906G DOES'NT START
Factory reset the phone and see if it fixes it. Possibly the firmware is corrupted and needs a reload. This will do it
You do this by holding down the # key while the phone is powering up. The screen will prompt you with a message that the reset sequence has started. At that point you hit the following key sequence 123456789*0# The phone will then prompt if you want the network configuration saved choose no.
That will allow your system to recognize the phone from scratch.
105
