7906G in boot loop
probably this is a case for an RMA but if anybody has a secret key combination to do more than a factory reset I'd be happy to read that.
My phone lights the LEDs, then shows the Cisco Systems, Inc. Screen but then reboots. I can factory reset it (1234....), it is able to download the actual software from CME4.1 (I can see that with debug tftp events) but in the end it is not able to boot completely and continues to try booting over and over again.
As the sequence of activities during booting is not described anywhere I do not really know where it gets stuck. If anyone has some info or an idea I'd be happy to read it.
Load is SCCP11.8-2-2SR1S, IOS: 12.4(11)XJ3
Thanks anyway.
Mat
Silver
Re: 7906G in boot loop
try to unzip the SCCP11.8-2-2SR1S in a tftp server on your laptop/pc and assign option 150 to your DHCP server with th ip address of this tftp server (or statically on ur 7906) and see tftp logs in ur tftp program.
i tried this previosly with sccp and sip and it worked fine.
hth
/majdi
i got the same problem but my load is
SCCP11.8-0-4SR1S
i will try this way, ill let you know if it work for me, thanks /majdi
277
