7911 ip phone hang while load file upgrade
While new installation 7911 ip phone are getting hang in the process of load file upgrade from SCCP11.8-3-2S to SCCP11.8-4-1SR2S due less bandwidth between CCM & IP phone. In hang ip phone its key and display does not work even after rebooting. Even factory reset keys does not work. Is there any way to make these hang ip phone work again.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 7911 ip phone hang while load file upgrade
If you search the forum, it has been discussed many times.
Of course you have to unzip the files as mentioned before.
Yes, use tftpd32, set dhcp option 150 to be PC address, and you should be able to load all files.
plz tell mw what all file I need to keep in tftp server root directory. Is any cahnge in file name is required.
Abhas Jain
All the files found in the .ZIP distribution.
Is there any document available for this?
Do I need to unzip & then put file in tftp?
Abhas Jain
Hi abhas,
Please tell me how to do the same.
I'm also facing the same issue.
Good day...
697
