Community Member
7911 - Octoline Support ???
I use extension mobility and between a soft phone and my 7911 desk phone, when I am at home and on occasion provide remote support for our engineers on the road and I would like to be able to take and hold multiple calls -  so I set my extension as an octoline using the command ephone-dn octoline then logged out and back in on the softphone and everything was working fine.
When I came back into the office and logged into my 7911 desk phone it seemed to login as usual but then I had no ext. number and I couldn't make or receive calls. As soon as I switched the config back to dual line the 7911 worked again...
Is this a limitation of the 7911 phone?
Is there a workaround?
Everyone's tags (3)
Re: 7911 - Octoline Support ???
I'm not sure but there is overlay mode while configuring button for ephone-dn on cme.
Overlay lines are ephone-dns that share a single button on a multibutton phone
Haven't heard about same thing on cucm. So it seems like cme can display more buttons while cucm has hard coded button number.
Again, not sure for 100%
Hall of Fame Super Gold
Try updating IOS.
