Community Member
7911 SIP image
Hi.
A couple of months ago I bought two 7911.
The last week I try to register one of this phones against a SIP server but I dint know how to upgrade the image from SCCP to SIP.
Someone know which files I need in my tftp to upgrade it?
Hall of Fame Super Gold
Re: 7911 SIP image
the matter is that to download the SIP image files, you need to register a support contract (aka smartnet) for the phone. It is not expensive and should be available from any serious authorized cisco reseller.
Community Member
Re: 7911 SIP image
I already download the Sip image into the phones, but those doesn't register in the Sip server. In the XML archives I also point to the Sip server IP, but nothing yet. Do I need to edit more parameters of the XML files, if so, which ones?
Any ideas
Re: 7911 SIP image
Hi, look at this for a guide for configuring the XML file:
http://www.voip-info.org/wiki/view/Standalone+Cisco+7941%252F7961+without+a+local+PBX
on the same site there are many articles regarding use of cisco phones with third-party SIP.
300
