7911G "registration: no configuration file..."
Dear all,
there is band new configuration of ISR 2811 with CME.
telephone 7911G is obtaining new firmware files, IP etc but at the end I get message:
Registration: no configuration file...
Onto flash memory I have a lot of .xml files:
40        1264 Apr 2 2012 15:46:32 +02:00 its/vrf1/XMLDefault7911.cnf.xml
here is my CME/ISR2811 config:
#sh run
Building configuration...
Current configuration : 4383 bytes
version 15.1
service telnet-zeroidle
hostname CTtest
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M3.bin
boot-end-marker
aaa new-model
aaa authentication login lokalne local
aaa authorization exec lokalne local
aaa session-id common
clock timezone CET 2 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.168.1.1 172.168.1.9
ip dhcp pool pula_VOICE
network 172.16.1.0 255.255.255.0
option 150 ip 172.16.1.1
dns-server 10.0.0.2
default-router 172.16.1.1
ip domain name ct.corp
ip name-server 10.0.0.2
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn xxx
archive
log config
  hidekeys
username xxx
redundancy
no ip ftp passive
ip tftp source-interface FastEthernet0/0.90
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description interface for LAN
encapsulation dot1Q 10
ip address 10.0.0.253 255.255.255.0
description interface for VOICE
encapsulation dot1Q 90
ip address 172.16.1.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.0.254
tftp-server flash:/7911SCCP/term06.default.loads alias term06.default.loads
tftp-server flash:/7911SCCP/term11.default.loads alias term11.default.loads
control-plane
mgcp profile default
telephony-service
no auto-reg-ephone
max-ephones 24
max-dn 48
ip source-address 172.16.1.1 port 2000
cnf-file location flash:
load 7911 SCCP11.9-2-3S.loads
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 02 2012 15:48:11
line con 0
line aux 0
line vty 0 4
exec-timeout 60 0
login authentication lokalne
transport input telnet ssh
transport output telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 212.244.36.227
end
3 ACCEPTED SOLUTIONS
Blue
Why are using command no auto-reg-ephone under telephony service.
If you use this command you have to add manually this phone to create its configuration file. give auto-reg-ephone or add phone manually.
regards
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Please enter following command
under
telephony-service
time-zone
Select time zone which is correct to your zone.
Also configure clock summer-time .
After this do creat cnf file.
Ronak patel
Rate helpful posts.
Blue
you have not created ephone and ephone dn
1) Create Ephone-dn
2) Create ephone and under it add mac address of the 7911 phone.
3) Assign the above dn to this phone.
4) Reset ephone
You will get the dial tone.
regards
Ronak patel
Blue
regards
Ronak patel
Rate helpful posts.
Thnak You,
auto-reg-ephone
solves my issue.
Now, why onto telephone date is correct, but time is 2 hours back than onto CME?
CME:
#sh clock
09:56:55.599 CET Tue Apr 3 2012
7911G:
7:57a 04/03/12
Blue
Re: 7911G "registration: no configuration file..."
What firmware your 7911 phone has.
Ronak patel
Rate helpful posts.
Dear Ronak,
how can I check it what firmware do I have ?
onto CME/ISR2811 flash I have (from there firmware was upgraded):
7911SCCP/apps11.9-2-3TH1-9.sbn
7911SCCP/cnu11.9-2-3TH1-9.sbn
7911SCCP/cvm11sccp.9-2-3TH1-9.sbn
7911SCCP/dsp11.9-2-3TH1-9.sbn
7911SCCP/jar11sccp.9-2-3TH1-9.sbn
7911SCCP/SCCP11.9-2-3S.loads
Blue
under
telephony-service
time-zone
Ronak patel
Rate helpful posts.
Dear Ronak,
You have my inital config of CME\ISR2811.
What do I have to configure, what is missing to hear a "ready" signal in my telephone 7911G?
Now the line is numb.
Blue
1) Create Ephone-dn
4) Reset ephone
regards
Ronak patel
738
