7911G (SIP) can't register
Dear all,
I have upgraded 7911G from sccp to SIP, I have configured my CME, but 7911 is registering endlessly.
On sccp firmware it worked fine.
Here is debug output:
Apr 16 07:14:27.472: VOICE_REG_POOL: key(6BAA39900001DD48) added to nonce table
Apr 16 07:14:27.472: VOICE_REG_POOL: Contact doesn't match any pools
Apr 16 07:14:33.124: EVENT: 1 node in nonce tree obsolete
Apr 16 07:14:33.124: VOICE_REG_POOL: deleted key(39F2AB1E0001C800) from nonce table
Apr 16 07:14:35.472: voice_reg_get_reg_expires_timer: no voice register pool found
Apr 16 07:14:35.472: VOICE_REG_POOL: Register request for (889) from (172.16.1.2)
Apr 16 07:14:35.472: auth absent
and my CME config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
  registrar server
voice register global
mode cme
source-address 10.0.0.253 port 5060
max-dn 5
max-pool 5
load 7911 SIP11.9-2-3S
authenticate register
authenticate realm computec.pl
timezone 23
tftp-path flash:
create profile sync 0010612423542201
voice register dn  1
number 889
name Tel01
label 889
voice register pool  1
id mac D824.BDBA.2483
type 7911
number 1 dn 1
dtmf-relay sip-notify
username 889 password 123
codec g711ulaw
tftp-server flash:7911SIP/SIP11.9-2-3S.loads alias SIP11.9-2-3S.loads
telephony-service
max-ephones 24
max-dn 48
ip source-address 172.16.1.1 port 2000
cnf-file location flash:
time-zone 23
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 16 2012 09:12:14
thanks in advance and regards
GN
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
No. Other PBX doesn't know anything about your phones. It only communicates with CME, via SIP, exclusively.
Why SIP? You only gain trouble and bugs, but loose features in doing that.
Use SCCP and everything will work good.
I plan to establish SIP trunk from CME to Microsoft LYNC server.
I tought that I have to use 7911G phone as SIP phone to call to LYNC users.
I'm I right?
1322
