7912 goes into constant loop
Thanks to Jonathon Schulenberg from previvious post to putting me on correct path.Further help needed please
7912 goes into constant loop of Configuring IP, Configuring VLAN,Configuring CMList
Network Configuration on phone shows allocated IP addresss, default gateway, etc of which is correct
Can ping phone, DHCP and def g/w from router ok. But cant stop this constant looping
Runnng CME 3.3 with IOS 12.4
Phone has necessary sbin file according to cme and IOS matrix
Phone displays in CME with correct extension number, caller id/name, mac address and phone loads
Provided output below via attachment of sh telephony-service all and show ephone for more information
Am I doing something wrong....thanks again in advance..
cme_router#sh telephony-service all
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 192.168.3.0 port 2000
load 7912 cp7912060000sccp050124A.sbin
max-ephones 2
max-dn 2
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web:  enabled.
edit TIME through web:  enabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Mar 01 2002 17:50:44
transfer-system full-consult
local directory service: enabled.
ephone-template 1
ephone-dn 1 dual-line
number 1001
name John Cheetley
description Garage phone
preference 0 secondary 9
huntstop
no huntstop channel
translate calling 1
translate called 1
call-waiting beep
translation-profile incoming 1
translation-profile outgoing 1
ephone-dn 2
number 1002
huntstop
call-waiting beep
Number of Configured ephones 2 (Registered 0)
ephone 1
mac-address 0017.9570.8E67
type 7912
ephone 2
voice-port 50/0/1
station-id number 1001
station-id name John Cheetley
translate calling 1
translate called 1
voice-port 50/0/2
station-id number 1002
dial-peer voice 20001 pots
destination-pattern 1001$
huntstop
progress_ind setup enable 3
port 50/0/1
dial-peer voice 20002 pots
destination-pattern 1002$
huntstop
port 50/0/2
tftp-server system:/its/SEPDEFAULT.cnf
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/ATADefault.cnf.xml
tftp-server system:/its/united_states/7960-tones.xml alias
United_States/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias
English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias
English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias
English_United_States/7960-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias
English_United_States/SCCP-dictionary.xml
tftp-server system:/its/XMLDefault7912.cnf.xml alias SEP001795708E67.cnf.xml
directory entry 1 1001 name John Cheetley
show ephone output
cme_router#sh ephone
ephone-1 Mac:0017.9570.8E67 TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0
IP:0.0.0.0 0 Unknown 0  keepalive 0 max_line 0
cme_router#
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
You do not need any of these tftp-server commands.
However, you should urgently update IOS.
Thanks Paolo for your reply.
As there are varied IOS updates available for the 2691 multi service platform router
IE
c2691-adventerprisek9-mz.124-25d.bin,
c2691-advipservicesk9-mz.124-25d.bin
Or perhaps
c2691-ipvoicek9-mz.124-25d.bin
Do you have a suggestion?
Can I only put a 2691 IOS onto  a 2600 router or are routers "forward" IOS compatable dependant on features using?
249
