7912 lost directory feature after upgrade
jupchur
We have a customer with several hundred 7912 IP phones. After upgrading from CM 4.X to 6.X the corp directory serch feature no longer apperas on these phones.
Is this a known issue and is there any way to get the directory back?
Justin
5 Replies 5
gogasca
Level 10
Level 10
Can you check if under Device they are not using anything hardcoded different from what the other devices have?
We have the same problem. Nothing is configured on the phone for directories.
When clients try to access the directory from an 7912 phone is just says it's unavailable. Directory access from all other phones works fine.
Hi Brian,
This may be a Firmware issue on the 7912's as there are some known bugs relating to the Directory. Can please let us know what these are running?
Rob
Thanks for the reply Rob...
They're using CP7912080003SCCP070409A
Hey Brian,
No worries my friend! I'm guessing that the upgrade took the phones firmware to 8.0.3? Have you tried your previous firmware on one of the phones?
I would be tempted to open a TAC case as there are bugs in 8.0.4 as well and they may be able to offer something new with fixes.
Just a thought,
Rob
