7912G Background Image
I've found numerous sources for changing the background image on a 7912 to something else.
I am looking for a way to change it back to the Cisco logo. How does one REMOVE a background
image going back to default? I've tried factory reset with no luck.
Holbrook
paolo bevilacqua
I am looking for a way to change it back to the Cisco logo. How does one REMOVE a background ggggimage going back to default? I've tried factory reset with no luck.
Apparently there is no way to do that. You can only upload a different image.
Upgrading/downgrading the firmware seemed to do it.
