7914 lamp color on CM6
hi all,
we configured a 7960 device profile with 7914 module for presence and sd. We see the 7914 lamp off when the directory number is free and red when is busy. No steady green/amber, no flashing green/amber...
Where we made the mistake?
Best regards.
Silver
Re: 7914 lamp color on CM6
You can check the details of this bug:CSCsl38701. try upgrading the phone load it should solve the problem.
Hall of Fame Super Gold
Hi, CSCsl38701 is "The flashing shared line button is not able to resume a call in case of a cBarge by another shared line".
Beside not looking applicable, the bug is still unresolved and no FW upgrade would help.
Bronze
i got the same think on my CCM 5.1.2 system. any ideas?
Bronze
This is the expected behavior of a BLF/SD.
145
