7914 on 7960 - lights to show if ext is on the line
Running Call Manager Business Edition  7
We have 7960 phones with 7914 expansion units.
They have been setup with ext numbers and names but is there any way that we can get the buttons to light up when an ext is on the phone.
That way our receptionist can advise the caller that they will go to voicemail and can leave a message or they can call back
Thanks in advance
Re: 7914 on 7960 - lights to show if ext is on the line
Not with the 7914. The newer side cars / expansion modules do support buttons that light based on various parameters. For remote line in use, it glows red while the line is in use (for example). one such sidecar is the 7915. It is not compatible with the 7960 however.
Hth.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hall of Fame Super Red
Hi Jenny,
Bill is probably right ...but I could have sworn
If these are "shared lines" that are on both the Primary user phones
and a button on the 7914 as well, they should light Red when then
user is on their appearance of the "shared line".
Have you tried changing the Privacy setting on the user's
phone configuration page?
Cheers!
Rob
+5 to Rob you can get the lights to work if you set them up as shared lines.  This will give you the following information on the lights:
Lighted Buttons—14 buttons. Each button corresponds to one line (just like on the Cisco IP Phone). The lights beneath each button indicate the state of the corresponding line as follows:
Line available: light off
Line in use by you: steady green light
Line in use by someone else: steady red light
Line ringing: flashing amber light
You have a call on hold: flashing green light
Someone else has a call on hold: flashing red light
Call transfer: steady green light
From the 7914 guide:  http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7914/4_1_3/english/user/guide/14qsbar.pdf
Yes, +5 to Rob and Budmiller, -5 to me This is what happens when you trust my memory I suppose! Thanks Rob and Bud for coming in and setting me straight!
Bill
Hey Bud & Bill,
Thanks to both of you for weighing in on this +5 each my friends.
It's been awhile for me to setup this config so I was going to try it in the
lab later on. But now you've freed me up to do other tasks (which one of the
other 39,437 to do now ...hahahaha!!)
Bill ...no -5 for you buddy, you deserve +500 for all your hard work here!
Cheers!
Huff
417
