Community Member
7914 Supported Phones
I am confused by what phones support the 7914 expansion module. Specifically does the Gigabit version of the 7961 support it? I am not having luck getting it to work so far.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 7914 Supported Phones
Hi Brian,
The 7914 "is" supported with the 7961G-GE
CISCO UNIFIED IP PHONE EXPANSION MODULE 7914 SUPPORT
An optional 14-button add-on module, the Cisco Unified IP Phone Expansion Module 7914 (part number CP-7914=), provides 14 additional buttons for programming directory numbers or speed dials, or a combination of the two. Up to two modules can be used with the Cisco Unified IP Phone 7961G-GE.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps6512/product_data_sheet0900aecd802ff030.html
Hope this helps!
Rob
OOOPS! Sorry Java my crappy typing skills have let me down once again :)
Hardware Requirements
• Cisco Unified IP Phones 7960G (CP-7960G), 7961G (CP-7961G) , 7970G (CP-7970G) and 7971G-GE (CP-7971G-GE)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Brian,
Hope this helps!
Rob
293
