7914 will work with CM, but not CME
I have a 7914 that works when I connect it to my CM version 8.5, but will not work when connected to my CME version 4.1(0). Is there any way to reset the 7914 to factory default?
I have the proper load command under Telephony Services and the proper command under tftp-server.
Nothing seems to help.
1 ACCEPTED SOLUTION
Green
There are quite a few bugs for 7914,
Not sure if this one is may be affecting you.
CSCsw25514 Bug Details
7914 fails to re-register after 'reset' is issued on CME 4.3.
Symptom:
On CME 4.3/7.0, when issuing a 'reset' for a 7960 with a 7914 sidecar, the 7914 will fail to re-register to CME and will stay with all buttons red.
Conditions:
This is observed on CME 4.3 and 7.0 for the 7960 with the 7914.
Workaround:
Downgrade to 12.4(15)T7 (CME 4.1) where the issue is not seen. Another workaround is to rebuild the CNF files with the below commands. This will allow for the device to be reset a single time and register properly. Successive resets will fail until the CNF files are rebuilt again.
CME#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
CME(config)#telephony-service
CME(config-telephony)#no create cnf-files
CNF files deleted
CME(config-telephony)#create cnf-files
Creating CNF files
Alex
Regards, Alex. Please rate useful posts.
Green
7914s do work with CME
Your version 4.1.0 needs at least loads file S00104000100.sbn
Under your ephone config you need something like this :-
ephone-dn 21 dual
number 2021
ephone-dn 22 dual
number 2022
ephone-dn 23 dual
number 2023
ephone-dn 24 dual
number 2024
ephone-dn 25 dual
number 2025
ephone-dn 26 dual
number 2026
ephone-dn 27 dual
number 2027
ephone-dn 28 dual
number 2028
ephone-dn 29 dual
number 2029
ephone-dn 30 dual
number 2030
ephone 11
mac aaaa.bbbb.cccc
type 7961 addon 1 7914
button 1:21 2:22 3:24 4:25 5:25
button 6:26 7:27 8:28 9;29 10:30
Alex
Hi and Thank you,
I have already included these commands.  Plus, I have the proper tftp-server flash: command and the load 7914 under Telephony-services.
The issue is that the 7914 does not get past all red lights on.  It seems to never load its firmware.  I also did a debug tftp, and I do not see the 7914 looking for its load.
Green
Symptom:
Conditions:
Workaround:
CNF files deleted
Creating CNF files
Alex
Hey Alex,
The above workaround did not work either.  I followed the instructions, and had no results.  All the lights were still red, and the 7914 did not reset.
Any other suggestions?
Scott
Green
Scott,
Can you post show run
Alex
ip dhcp pool CME-Phones
   network 10.2.130.128 255.255.255.224
   default-router 10.2.130.130
   option 150 ip 10.2.130.130
tftp-server flash:S00105000200.sbn
telephony-service
load 7960-7940 P00308000500
load 7914 S00105000200
load 7921 CP7921G-1.1.1
load 7931 SCCP31.8-3-3S
load 7961GE SCCP41.8-3-3S
load 7961 SCCP41.8-5-2S
load 7975 SCCP75.8-3-3S
load 7945 SCCP45.8-3-3S
load 7942 SCCP42.8-3-3S
load 7962 SCCP42.8-3-3S
load 7971 SCCP70.8-3-3S
load 7936 cmterm-7936-sccp.3-3-20
load 7911 SCCP11.8-3-3S
ephone-dn  4  dual-line
number 4020
label George - 4020
description George Smith
call-forward busy 1199
call-forward noan 1199 timeout 10
ephone-dn  20
number 125
name General Delivery mail
call-forward busy 199
call-forward noan 199 timeout 10
ephone  13
device-security-mode none
mac-address 0019.30D4.C8E5
button  6:20 7:4
Green
Scott,
I dont see anything wrong here at all.
I can only suggest that you raise a TAC case.
Alex
The bug fix worked!
793
