Community Member
7915 Expansion Module managed by end user
Is it possible to give permissions to an end user to customize a 7915 expansion module speed dials/BLF attached to his/her phone. Using CUCM 7.1(2)
Oscar Perez
1 REPLY
Hall of Fame Super Red
Re: 7915 Expansion Module managed by end user
Hi Oscar,
Sadly only the ccmadmin can setup BLF/SD even in CUCM 7.x.
Here is a reference to this fact;
Unified CM Speed Dial Presence
Unified CM supports the ability for a speed dial to have presence capabilities via a busy lamp field (BLF) speed dial. BLF speed dials work as both a speed dial and a presence indicator. However, only the system administrator can configure a BLF speed dial; a system user is not allowed to configure a BLF speed dial.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/presence.html
Hope this helps!
Rob
PS: You are one of many people that I have seen wanting this feature. I would encourage you to work with your Cisco SE to open a PER (Product Enhancement Request)
509
