7916 Expansion Module
Is changing the background image on the expansion modules possible? I know it wasn't a couple years ago but it seems like an easy feature to enable.
1 ACCEPTED SOLUTION
To the best of my knowledge this is still not possible, I don't think there is an enhancement request for this.
You may want to reach your Account Team to submit a PER.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Thanks! I just sent the email to my account team.
218
