7916 expansion modules
Anyone know if there is still a limit when you have (2) Expansion modules on a 79xx phone.  I know in
earlier releases of this device, you could only get to 48 lines or something odd like that.
The stats say 54 lines:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468673.html
But I know the last time I had a 7965+7916+7916  I think I only could get 48 lines, but I should be able to get 54.
Anyone know this?
Thanks!
Re: 7916 expansion modules
Hey Tommer
There's a little confusion there, the tables do not mention "lines" they mention "buttons"
AFAIK you should only get 42 lines with 7.X.
I believe the new CUCM will have support for having all buttons each one with their line.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Ok, so its still the same..  42 lines or speed dials or
BLFs on the phone with (2) 7916s.
On CUCM 8, they may change this?
Thanks Java!!
Hall of Fame Super Red
Hey TCAT,
Here are the details for this issue. This has been fixed in CUCM 7.1(3) versions with the 8.5(3) firmware, but no other versions.
Cisco Unified Communications Manager 4.2(3)SR3a, 4.3(2), 5.1(3)b, and 6.1(1), 7.0 and 7.1
Total Number of Buttons Supported
Cisco Unified IP Phone 7965G = 42
Cisco Unified Communications Manager 7.1(3) / Cisco IP Phone Firmware 8.5(3) and later
Cisco Unified IP Phone 7965G = 54
Cisco Unified Communications Manager Express 4.3 and later
From this 7916 Data Sheet;
Hope this helps!
Rob
well, there are two answers, so someone must be right.   I'll take Java on this one until I have a chance to build this out next month. I was hoping to have it confirmed.
The stat sheets says on thing, but a reality check is likely needed.
Thanks Huff
Hi there,
I just got the second page to work on the 7916.  We are running 7.1(3b) with the latest phone loads on both the phone and the modules.  It didn't look like it was going to work at first but then I read the instructions.  You have to change the phone button template.
Kristine
Ok, so I logged into my 7.1.3 cluster and built out 54 lines, or it is possible with the Phone Template for 7965.
I logged into the 6.1.4 cluster and saw you could only do 42 lines on the phone template for the 7965.
So looks like its fixed now.
Cheers!
Hi TCAT,
Thanks for posting back with your results buddy! +5 points
for this excellent follow-up
Happy Holidays!
Huff
879
