7920 noisy sound with OffNet Call
I have deployed the Cisco Aironet Access-Points, Call Manager 5.0(4) and we have registered a few Cisco 7920 IP Phones.
When calling each other [OnNet call] from 7920 Phones the voice quality is good and we experience no problems.
However when a call is initiated from the 7920 to the PSTN/GSM [OffNet] or vica-versa, i hear a "strange" clicking noise on the 7920 through the duration of the call.This sound start when I talk only and stop when I listen .
I have the lastest firmware running on the Cisco 7920 (4.0-03-01) and the Voice port configuration is :
voice-port 0/0/0
cptone BR
connection plar opx 5000
caller-id alerting dsp-pre-allocate
Any advice for this problem .
Hall of Fame Super Gold
Re: 7920 noisy sound with OffNet Call
I would try following this procedure to finely tune your FXO port impedance:
http://cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080477a06.shtml
I actually have a question for since you're in Brazil, does BINA work for you ? Since it is different from any other country.
Thanks p.bevilacqua,
I tried all the Impedance in the FXO port and I follow the procedure. I notice the clicking noise in some impedance start when the call initiator start talk and in other Impedance the noise clicking start when receiving end start talk.
regard your question about BINA ,I am not from Brazil but I use the BR cpton since it compatible with my PSTN
Do you have this noise with the 7920 only, or with other phones types also ? What is the impedance recommended by the thl sweep test?
The clicking noise happens only with the 7920 phons when making call to the PSTN/GSM only.Ther is no any noise happen when making calls to a local ext even for 7920 ext.
about sweept test ,I am not sure what do you mean by this test.
HI everybody, I have the same issue with Cisco 7920 (4.0-03-01)when I receive a call PSTN I hear a crackling noise when the party on the PSTN talks.
On gateway of the CallManager 4.2(3) I?m running a CCME also.
I registered the Cisco 7920 and there is no noise from PSTN CALLS.
REGARDS.
ANY HELP WILL BE VERY APRECIATED.
WALTER
I want to add that the click noise hapen only when I talk on the 7920 but ther is no any clicking If I am listen from other side.
WALTER,,
is that happen aslo with you.
NO.
When I received the call from PSTN and the party on the PSTN side talks is when I heard the noise.
regards
Walter
I would like to add I upload to the latest firware the Cisco 7920 (7920.4.0-03-02).
But the noise problem continuest he card to PSTN is E1 PRI ISDN.
REGARDS.
Walter Flores
Yes I just found the soultion,,,
you need to disable the VAD from the dialpeer
[no vad] ,and this only for VOIP dialpeer.
I'm experiencing this problem too. I have "no vad" configuration in dial-peers. It is not the exact solution.
HI YHAB
I configure NO VAD on dial-peers and this resolver the noise on call.
THANK VERY MUCH FOR HELPING
WALTER FLORES
hi WALTER
I am very happay since it work with you also
Dear ozgurguler,
actually you will not find VAD in the pots dial peer since this feature work with voip dialpeer only try the below for voip as example:
dial-peer voice 111 voip
no vad
Just curious: any idea why this (seemingly) only happens with 7920s?
197
