7920 stuck on connecting to callmanger 0
tgibson
I am using a 2811 router with CCME on it and have a hwic ap. I am trying to get a 7920 to work. All the display says is connecting to callmanager 0. The phone picks up a dhcp address,tftp address and can ping the phone address. I have attached config. Any help would be great. Have spent hours looking for it on the web and cant find anything.
jason-calbert_2
Level 3
Level 3
There is a bug out there on this. It might be internal. If you upgrade to the newest device load for the 7920 it should fix your issue. I have seen this a couple of times.
